Can anyone help me? What is the replacement MOSFET for apm2054? My motherboard is dead and the MOSFET seems to burnt. But i can't find this part in the electronics store. Also, do i need to replace all other similar MOSFET or just the visibly burnt one? Thank you in advance
Mosfet apm2054
Re: Mosfet apm2054
I have searched your and I found 3 types, 2 are in different package and one has different characteristics, so you have to identify correctly which one you need (see attached datasheets).
Anyway the PowerMosfet usually died because something went wrong with controller so replacing only them could be not enough to repair your MOBO.
In my company we used PowerMos from STMicroelectronics and we can buy them from RSComponents.
You can check also Digikey or Farnell, it depends on where you live.
You have to compare datasheets: the maximum voltage, maximum RDSon, current drain must be as close as possible to the original part you are going to replace.
If you need help to compare datasheet I can help you, but before you must identify what you need.
If you can, post some clear picture of the damaged board and give more details about it if it is a known problematic MOBO maybe you can get better support.
Ciao
GianniAttached Filesif you find these attachements useful please consider making a small donation to the site
"In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
H. J. Brown -
Re: Mosfet apm2054
Wow, you are very helpful. I don't have the motherboard right now, but i placed a PC analyzer, without the memory, it stops at "CC". And when i place the memory, it pauses at "D3" and stops at "D4". I'll try to check if the PowerFet is available here.Comment
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by NooyHello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet... -
by IamPriteshSo I have this Asus GT531GT whose pad is burnt and it shows short to ground 0.8 even after removing all the connected mosfets and capacitors.
Image attached . The mosfet where the pad is burnt is PQH8102... -
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... - Loading...
