What component ?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8695
    Re: What component ?
    The failure of the shock sensor probably would not cause the drive to fail, or at least it shouldn't. From the fact that crystals should be pretty quiet when not struck, it should look like an open circuit (or a few Kohms). However it may be used to detect vibration of the disk and compensate for it...
    Piezoelectric crystals tend to be very reliable and I wouldn't suspect it broken unless physically destroyed.
      • 30977
      if the cover is brown and says "Turuta" then yes.
      look at his thread
      https://www.badcaps.net/forum/showthread.php?p=507366
      • bianchi77
        • Jun 2016
        • 1121
        I can't find any electrolityc capacitors on 5V rails...so it will not be the faulty caps...
        but 2 TVS diodes are on 5V rails which was hit by 12V accidentally....
        Thanks for the link...
          You are not going to find lytics cap on these HD PCB. The TVS Diodes show 0 OHMS?
          • bianchi77
            • Jun 2016
            • 1121
            TVS diodes are showing a value for forward and reverse test...on board..10K analog multimeter..
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              [QUOTE=bianchi77;694427]Everyone,
              What component is that ?
              I see it near inductor on 320Gb HDD board from Seagate
              Is it blown capacitor or TVS diode ?
              Cheers[/QUOTE
              So I agree with eccerr0r this is shock sensor for the hard drive. It has a max rating of 10 V p-p from A to B. It has all the markings of a shock sensor and not the markings of the smc 2pin component. If this is still what you are talking about?
              • bianchi77
                • Jun 2016
                • 1121
                [QUOTE=keeney123;694665]
                Originally posted by bianchi77
                Everyone,
                Cheers[/QUOTE
                How about those TVS s are they faulty already ?
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  [QUOTE=bianchi77;694701]
                  So your picture from post one show this as a shock sensor. If you look at the links below; the smd codes and murata shock sensor it looks just like the shock sensor. If you are talking about some other component then in post one do you have a picture for that components of the TVS suppression diode? I would need to know the out of circuit measurement, if the TVS is uni or bi directional. With bi you will get diode reading either way. Uni you will get diode reading one way. This would be done on lowest resistance scale on a analog meter or diode setting. You should not have a direct short 1 ohm or less. If the diode is good than the battery of the meter will forward bias the diode on the resistance setting and the reading will deflect the needle significantly above o ohms on the lowest scale setting.
                    BTW, where is the pictures of the whole board?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      The whole board....not many major components on it...main CPU, RAM, motor controller...
                      Will the CPU die, if there's a voltage spike ?
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        So it looks like the largest IC has traces that are broken on the top of the ic, there is eyelet holes that seem damaged. I can not read any numbers on the IC. It maybe the main CPU. It would also be nice to see the back of the board.
                          • 30977
                          did you check all those 0-ohm resistors over the power inlet?
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Which one area are you talking about ? could you mark it ?
                            Ok, I'll take photo for the other side ...
                            • bianchi77
                              • Jun 2016
                              • 1121
                              Ok, I'll do that,
                              one of the TVS diode is short, showing value on both test reverse and forward...
                                • 30977
                                if there is a short, it could burn out those resistors - that's why i'm asking
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  Some photos :
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    how can I know if it's burned ? Open line ?
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Have you checked out those photos ?
                                      Please let me know where it is ?
                                        Ok, I'll do that,
                                        What is the RESISTANCE READING of the TVS off the board?
                                          • 30977
                                          check the resistance across it - it should be - 0 ohms.
                                            Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                            by momaka
                                            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                            09-19-2021, 08:44 PM
                                            HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                            09-12-2024, 02:00 PM
                                            HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
