How to find SMD equivalent
  • Jane
    • Aug 2010
    • 189
    What methods do you use to find an equivalent of a SMD part?
    It is rather difficult to find it ( at least for me) because SMD parts do not have model number written.
  • adigrf
    How can I find this chip equivalent?
    by adigrf
    Hello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
    What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
    Do you think this is real ?
    The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
    06-22-2025, 12:37 AM
  • trepachka
    Trying to find an equivalent component Inspiron 7706
    by trepachka
    Hello, I have this Inspiron 7706 that is not starting. It flashes 5 white/3 amber combination indicating "Power rail failure".
    I found this shorted component U6601 on the motherboard with markings "53BC". Accoring to the schematics it's SY6288DAAC-GP.
    They are available in China which means a 3 week wait.
    My question is this: is there an equivalent I can get quicker which will do the job? Thanks....
    11-30-2023, 04:27 AM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
    Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
    by sam_sam_sam
    This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
    Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
    07-07-2024, 02:34 PM
