How to find SMD equivalent
  • Jane
    • Aug 2010
    • 188
    What methods do you use to find an equivalent of a SMD part?
    It is rather difficult to find it ( at least for me) because SMD parts do not have model number written.
  • trepachka
    Trying to find an equivalent component Inspiron 7706
    by trepachka
    Hello, I have this Inspiron 7706 that is not starting. It flashes 5 white/3 amber combination indicating "Power rail failure".
    I found this shorted component U6601 on the motherboard with markings "53BC". Accoring to the schematics it's SY6288DAAC-GP.
    They are available in China which means a 3 week wait.
    My question is this: is there an equivalent I can get quicker which will do the job? Thanks....
    11-30-2023, 04:27 AM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
    Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
    This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
    Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
    07-07-2024, 02:34 PM
    by Vesko356
    08-11-2023, 03:27 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
