Half a volt below rated voltage
  • espresso
    • Aug 2008
    • 24
    • Serbia
    Hi
    I have this simple audio amplifier incorporating Hi-Fi ic TDA2616 which provides me with 2x12W for my room.
    Now, since I'm replacing existing 10W speaker drivers with Visaton's FR10 (20W) I thought I could also replace the old filtering capacitors (from 1999) and replace all small electrolytic caps with WIMA blocks. Plus stronger diodes in Graetz rectifier - RL207 (2A) instead of 1N5398 (1.5A).
    The original filtering capacitors were 2x4700 uF/25V (symetrical supply 2x15.5V).
    I have just replaced them with 2x 10 000 uf/16V because 25V ones wouldn't fit. As you can see the operating voltage is just half a volt below rated voltage for the capacitors. Will this significantly decrease their endurance? What can I expect?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Half a volt below rated voltage
    Well I don't have the answer about endurance, it depends on several parameters and on the type of cap you are using; give more details like Brand/Type.
    The only thing I wouldn't do is to use a cap with a voltage so close to the circuit voltage; I have always seen that a minimum margin is kept is more then 0.5V:
    on 5V caps are --> 6.3V/10V
    on 12V caps are --> 16V/25V
    Just my experience, maybe another member can give more info.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • arneson
      • Sep 2005
      • 1267
      That is a good simple retrofit
      but I would have not jumped that high
      and I would have stayed at the rated 25v.
      Just my thought,
      hope it sounds clean.
      Jim
      • espresso
        • Aug 2008
        • 24
        • Serbia
        Thanks for your answers.
        The capacitors are Fujicon brand. I haven't been able to find much info about them on this site but I would rate them as ok from my experience.
        TDA 2612 sounds pretty good and I'd say it's ideal for small budget applications like mine.
        I would also say 4700uF is sufficient but I was curious to see how the amp would behave with double that much. I think this can't hurt besides the voltage issue which I'm not sure about.
        • gdement
          • Jan 2007
          • 690
          16V is only 3.2% above 15.5v. I'd have serious doubts that the tolerances are really that good. Thus they may end up overvolted, but then the caps may also outperform the advertised limit.
          • espresso
            • Aug 2008
            • 24
            • Serbia
            They most certainly outperform it in a way that the cap won't explode if put to 40% higher voltage. I've had a 16v capacitor that had been working on 19V for a year (until I decided to save him). I don't know if he liked it because he never showed me he was unconfortable
            However my 1.0F gold cap wasn't so lucky cause it died even though the applied voltage was only 0.1V higher than rated (5.6V instead of 5.5V).
            Still, I am bothered by the question of quick aging at maximum voltage.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The max voltage rating is not just nominal voltage it's nominal+ripple.
              Mann-Made Global Warming.
              - Dr Seuss
              • Perry Babin
                Operating caps well below rated voltage
                by Perry Babin
                I think this has been answered but I couldn't find the thread.
                Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                Or would it require reforming?
                05-23-2024, 05:43 PM
              • UserXP
                Transformer producing higher voltage than rated
                by UserXP
                Hello, people.
                i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
                So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
                09-02-2025, 12:42 AM
              • Fernon@Repair
                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                by Fernon@Repair
                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                VCCIO voltage ok
                VCCSA Voltage OK
                VCCPLL Voltage OK
                Ram Voltage ok
                RamVTT OK
                VPP 2.5 OK
                But No Core Voltage
                and i want to this vrm ic datasheet or pinout (ISL69269)
                anyone have this ic pinout voltages?...
                06-25-2025, 07:19 AM
              • electron_jj
                Panasonic TH-L42D25A checking the PSU output voltage
                by electron_jj
                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                08-29-2021, 08:13 AM
