I am very new to soldering small electronics. I am attempting to fix a power supply on a TV and continue blowing a fuse. Wondering if it's my bad soldering or something else. The solder job doesn't look good and I've burned the pcb in areas, however if I check continuity from the pin I soldered to the other end of the trace, it tests good. No solder bridges between pins either. Is this good enough of a test to ensure the solder is good enough? Any help is much appreciated. I can attach pics later, but quite frankly it's embarrassing. Lol thanks
Testing soldered connections
by GlavalHello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...3 Photos
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:02 AM -
- Loading...
