Smd rework - Solder balls squeeze out
  • caphair
    • Nov 2011
    • 1249
    Can anyone explain why and how to prevent solder that seems to squeeze out under a BGA chip when reworking or applying heat for removal?
    Have a couple iPhones been working on and it's happened twice on various chips like the NAND and CPU
    I know iPhones use underfill but could that be the reason?
    • 31254
    Re: Smd rework - Solder balls squeeze out
    it could be underfill expanding, the only other way is if you push down on the chip
    • caphair
      • Nov 2011
      • 1249
      I'm guessing using flux would only make it worse if underfill is creating the issue?
      How would you rework ics that use underfill?
        • 31254
        no idea,
        i suppose you lift the chip and clean off the underfill.
        then re-ball and put back down.
        personally i dont touch such stuff.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Here is and article than explains on type of underfill attached.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            This lady has some good guides on her youtube channel this is about underfill ics
            https://www.youtube.com/watch?v=FUKJaf029tY
            • badcaphunter
              • Jan 2016
              • 88
              • England
              Jessa's channel is good for IPhones/Ipads and Louis Rossman's channel focuses on mac book motherboard repairs
              IPhones/IPads
              https://www.youtube.com/channel/UCPj...e1o_lp1US9TpWA
              MacBooks
              https://www.youtube.com/user/rossmanngroup
              • Deusjevoo
                • Sep 2010
                • 21
                What you use? Hot air? IR? Rework station? Do you preheat?
                Photo of setup and pcb/underfilled chip?
                • menshawy
                  Question about solder paste vs solder balls
                  by menshawy
                  hi friends
                  what about using solder paste to reflow vram because it is easier than solder balls
                  but it will working perfectly or it will die after short time ?
                  I need your experience
                  thanks
                  12-04-2021, 07:49 AM
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • petemanuk
                  BGA solder balls not connecting - help pls
                  by petemanuk
                  So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                  I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                  I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                  11-16-2022, 05:21 AM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
