I'm working on my Seadoo. There's a beeper (technically called a "buzzer", but it beeps) powered off 12 VDC battery. It's a "logic" thing, one beep means no key, two beeps means ready to start, etc... about 1 1/4" cylinder, has two wires (positive and negative) going to it. There's several repair options, but the easiest is to simply cut the wire, splice in a new beeper. If it weren't wet, I'd use small electrical screw caps and electrical tape, or those tube-style connectors you crush with two wires in it, but this is a Seadoo and it will get wet, so I want to know how to splice two 12-volt wires together so that water can't penetrate the repair.
Ideally, in my mind I imagine covering the spliced wires with heat shrink, and using a syringe to inject some kind of liquid rubber into the tube. Then heat the heat shrink up and everything hardens. I doubt that kind of thing exists, but that's what I imagine would be best.
