iPhone 6 no power - Hot power ic
  • caphair
    • Nov 2011
    • 1249
    Have a water damaged iPhone 6 that's been cleaned of all corrosion, however upon applying power the power management ic gets really hot and I measure 100mv to ground on all the surrounding smd caps
    I'm wondering if there's an easy way to determine if the ic itself is shorted or one of the smd caps?
    It's so tightly knit that simply unsoldering wouldn't be easy and the ic is BGA
    The power ic is highlighted in yellow
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: iPhone 6 no power - Hot power ic
    Possibly water under the bga chips shorting it out. Maybe try a reflow see if it helps ?
    • caphair
      • Nov 2011
      • 1249
      Hmm it gets so hot I'd imagine any water under there would be dry
        • 31015
        dont iphones have underfill-resin on the bga's like nokia first started?
        • caphair
          • Nov 2011
          • 1249
          Yes they do, would that prevent any water getting under there? Isn't underfill used to hold components in place during soldering?
          • caphair
            • Nov 2011
            • 1249
            Here's the section of the power management ic I'm looking at. Most those caps measure shorted and trying to figure out which one it is or the chip.
            However the diagram is a bit confusing, are all those caps tied to the buck section?
            • fzabkar
              • Mar 2009
              • 772
              All the buck regulators appear to share a common supply. The fact that the chip is hot while its supply is low (100mV) would confirm that it is the chip itself rather than a capacitor that is responsible for the overload.
              • caphair
                • Nov 2011
                • 1249
                Thank you for that, wasn't sure how to determine exactly if it was the ic itself
                • caphair
                  • Nov 2011
                  • 1249
                  Do you know the difference between vcc_main and vcc_main_s in that diagram?
                  Also what would the "desense" caps be?
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    Tankless hot water heater controller board not powering up when power is applied
                    by sam_sam_sam
                    I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                    I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                    However I would like to know if I could figure what happened to this controller board if possible
                    Tomorrow I will take some better pictures of both side of both boards
                    The...
                    12-09-2022, 09:14 PM
