In need of logic gates
+ More Options
Posts
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Re: In need of logic gates
    Originally posted by stj
    you could do that.
    but where does the flash chip get power when that programmer is doing it's thing?
    The power supply has two voltages (3 if we count the power enable rail). One is the 12V that's on when the console is on, and the other is the 5V standby, which is always present, this is where the nand chip is getting powered from.
    Keyboard not detected, press F1 to continue...
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Can you give me the type or model of a relay that's going to get the job done?
        • 30972
        anything wih 3 changeover contacts and a 12v coil.
        where do you like to buy from?
        • reaper57
          • Sep 2014
          • 216
          • Norway
          Ebay, preferably.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8694
            No-effort search
            http://www.ebay.com/itm/10-x-DC-12V-...-/301513195278
            I was about to choose a car relay for you that have 30A contacts that make really loud snap noise... and dump intense inductive feedback into delicate electronics... but decided not to, and instead chose something from China.
            • reaper57
              • Sep 2014
              • 216
              • Norway
              #26
              Originally posted by eccerr0r
              No-effort search
              Thanks! I'll be sure to check it out tomorrow (it's getting late)!
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
              • korben_dallas
                Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                by korben_dallas
                Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                MY QUESTION:
                I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                02-14-2024, 12:23 AM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
