18v li-ion battery charger. China make it as simple as it get
  • tibd
    • Oct 2014
    • 189
    • Sweden
    I got a hand on a 18v li-ion charger for screwdriver, upon disassembling it I got amazed by how simple the circuit board is. But question is is it working or not. I'm not by any mean electrician but would definitely like to get some info. The circuit consists of
    1 S9012 pnp
    1 10k resistor
    1 2.2k resistor
    1 1n4007 diode
    1 red led.
    Can anyone put a circuit with these components to make a working 18v li-ion battery charger??????
    If of any interest I can sure put some pics for the actual charger and its guts.
    Regards
  • larrymoencurly
    • Oct 2004
    • 960
    Re: 18v li-ion battery charger. China make it as simple as it get
    Is it one that stops immediately when the voltage reaches 4.1V per cell? Because otherwise I don't know a simple charger can charge lithiums.
      1 S9012 pnp
      1 10k resistor
      1 2.2k resistor
      1 1n4007 diode
      1 red led.
      Regards
      With just those component, I doubt that it is really made for charging the Li-ion batt, or for really charging any batteries properly (may be for low current charging for NiCad). It should have at least Charging management IC.
      http://www.futurlec.com/Transistors/S9012.shtml
      TO-92 0.65W 0.5A!
      Please post pictures.
        • Jul 2011
        • 6040
        Look at the battery pack cell and see if it has a protection board on it if it does not have one ether put one on it or stop using it
        • urbis
          • Oct 2014
          • 6
          I assume the battery contains most of the control circuitry.
          • desert-rat
            • Mar 2014
            • 4103
            I cut open a lap top battery just for fun. It's had about 6batteries and a board with some i.c.s .
            P.s. and what look like a thermister burried in the batteries.
              NVDC charger configuration...
              11-05-2024, 03:28 PM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
              Bauer tool battery pack charging with a HERCULES charger modification
              by sam_sam_sam
              The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
              Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
              05-06-2023, 12:17 PM
