Rubycon MFZ
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Rubycon MFZ
    read about them here. found a source today...
    it seems they are OEM caps almost only used in XBOX360s.
    50pcs, 2700uF 6,3V
    US $24,99 (~ EUR 15,90)
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=220153959028
  • hkivan
    • Mar 2006
    • 122
    Re: Rubycon MFZ
    How would it compare with MCZ ?
    • Phenos
      • Oct 2006
      • 46
      Re: Rubycon MFZ
      The ESR is 0.007 according to this datasheet: page 8
      • davidsays
        • Jun 2008
        • 4
        Re: Rubycon MFZ
        oh!
        Capacitors | Ceramic Capacitors | Tantalum Capacitors | Trimming Potentiometers
        • andlcs
          • Feb 2007
          • 22
          Re: Rubycon MFZ
          Here those MFZ on a 1st gen. Xbox 360:
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Re: Rubycon MFZ
            interesting article.
            • burom
              Xbox 360 Xenon Modern Capacitor Replacements
              by burom
              I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
              I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
              06-07-2024, 05:10 PM
            • bjs59
              Infamous Rubycon MFZ... Current recommended replacements???
              by bjs59
              What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
              12-10-2020, 10:47 AM
            • Satdude
              2700uF instead of 3300uF
              by Satdude
              Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
              02-12-2023, 06:23 PM
            • DXseekerMO
              Failed UCC and Rubycon replacement on a Dell XPS410, equivalent?
              by DXseekerMO
              Hello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
              If anyone has a link to where I can buy what I need that would be even better.
              These are the caps that have burst:
              Board location: C8BV, C26BV, C43BV
              Brand: United Chemi Con
              Series: KZG
              Size: 10mm dia X 25mm height
              Impedance: (ohms max/20c, 100kHz) .012
              Ripple: 2800...
              02-04-2022, 04:48 PM
            • blub0815
              Replacement of Chemi-Con KZG with Rubycon ZLJ
              by blub0815
              is the replacement possible? There is a difference of factor 2 between the ESR/Impedance.
              The caps are located on a motherboard.
              KZG:
              https://www.digikey.at/htmldatasheet...zg-series.html
              ZLJ:
              https://cdn.badcaps-static.com/pdfs/...a472c7fe84.pdf
              BR
              05-07-2023, 11:28 AM
