component id fuse or not?
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Hi everyone, attempting to bring this flash back to life from what appears to have been a drowning. This component appears to be a 5 amp ceramic fuse, but I am puzzled as to its location. It doesn't appear anything in this location has bus lines to the battery. Before I slap a new fuse in there and attempt to let out the magic smoke I thought it would be prudent to verify its really a fuse and not a ceramic cap.
    It says 5.00 with a logo of C surrounding M followed by K.
    Liberating magic smoke one part at a time
  • gabiz_ro
    • Mar 2011
    • 167
    • Romania
    Re: component id fuse or not?
    Looks like an crystal oscillator.
    Even from what I see from traces on PCB,2 small capacitor to ground,parallel 1M resistor,and connected to two pins of some MCU.
    • fzabkar
      • Mar 2009
      • 772
      uPD78062 datasheet:
      Pins 79 and 80 are X1 and X2 -- crystal (main system clock, 5MHz).
      The CM logo belongs to muRata:
        • 31144
        that's a ceramic resonator in a MELF package.
        the cobalt looking stuff is a sign of battery leakage from zinc/carbon battery's
        you will probably find the slide-switch is screwed too.
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          Ok glad I asked, learn something new everyday. It had lots of corrosion inside the pictures are after extensive cleaning. Still got nothing out of it after cleaning, it might be a lost cause as I just bought a working one off fleabay for 26$. Ill still keep it around for parts if I cant get it going again. Thanks for your insights
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • Andreasbest
            Lenovo Thinkpad T440p Backlight fuse location
            by Andreasbest
            Hello!
            I have a couple of T440p that need backlight fuse, image is present but no light. Can someone please point them so i can replace them?
            Thank you!
            Schematics: https://www.badcaps.net/forum/troubl...42#post1471142
            08-26-2024, 02:36 PM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
