LED power supply
  • diif
    replied
    Re: LED power supply
    Originally posted by michael dranfield
    Car in for a service as well !
    Now that's just showing off and taking the p*** lol
  • diif
    replied
    Wow, very nice indeed. Impressive stuff.
  • michael dranfield
    replied
    Originally posted by diif
    Those two Dongbaohe ?
    Could you suggest a better replacement ?
    Yeah, nice shop Michael, look at all those storage drawers
  • michael dranfield
    replied
    Thanks, I'm guessing you men the one that isn't there any more ?
    Oh wow, i always get a nice warm glow when i have the components to hand and don't have to order. Must be cool to have just about everything you'll ever need....and more
    Might be easier to drive to you than RS in future lol.
    Take a look at this , I have to stand on a chair to get to the draws next to the ceiling !
    replied
    that could explain the failure then!
    it's pulsed, but the fact that standard carbon resistors arent rated for that voltage dont help!
  • SteveNielsen
    replied
    Ohm's law says 12.96 watts. A 1/4w ain't gonna cut it.
    replied
    i wonder how much current that could pass at 360v?
    it was a 1/4w carbon job.
  • diif
    replied
    Originally posted by stj
    yes, but i cant make out the colour-codes from the first batch of foto's
    you need to use a 500v metal oxide job because it's connected to the rectified mains.
    it looks like it's(was) acting as a sort of pullup/down resistor on the gate/base
    if it had too low a resistance the current when the device was on could have slowly done it in.
    without it the transistor could have jammed on and blown.
    Brown, Black, Orange, Gold. 10kohms
    http://uk.farnell.com/panasonic-elec...tedCategoryId=
  • SteveNielsen
    replied
    I got an LM317 regulator smoking one day powering up a string of 8 LEDs taken from a small flashlight. I guess it's time for a better heatsink and new paste
    replied
  • diif
    replied
    btw, that carbon resistor is not rated for a high enough voltage, you need a 400v+ rated part there
    What you see is just a tiny part , I can park 3 cars inside , 4 if I tidied up a bit !
    Got more semis than a component wholesaler, the back room has no place left on the walls for any more draws !
    I will post some pics tomorrow .
  • michael dranfield
    replied
    replied
  • diif
    replied
    Originally posted by ReeceyBurger123
    Yeah maybe get a higher current one ? Also replace primary caps too as well as the resistor, diodes and possibly controller.
  • ReeceyBurger123
    replied
  • diif
    replied
    It was securely pressed up against the heatsink with paste and a clamp and the solder was fine.
    Does this look like a suitable replacement ?
    http://uk.rs-online.com/web/p/mosfet...stors/7192822/
  • ReeceyBurger123
    replied
    Here are mine stuck to the ceiling on pvc trunking, you will notice the fluorescent light on the ceiling, as my place is 1700 sq ft I dont have them on any more the whole place is lit with LED s put 12 volt to each end of your strip because if you dont the voltage will be lower at one end and the led s wont be as bright due to voltage drop , my first psu blew as the main reservoir cap dried out so I would replace this as well.
    Nice shop there
  • michael dranfield
    replied
  • ReeceyBurger123
    replied
    Just looking at the photos it looks like its barely even touching the chassis, it needs to be firmly pressed against it to cool.
  • ReeceyBurger123
    replied
    Ahh right, thats odd maybe it wasnt screwed to the frame tight enough as it doesnt look to firmly pressed against it and overheated ? Or maybe the transistor broke though the solder joints causing it to blow ?
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
