Roku 4 remote batteries draining out?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;i have a big issue with R4 remote control,besides the issue of not always turning on R4,also is eating butteries,when i got the R4 i noticed that the batteries that came with the box did not last more than a few days, i did not give it much importance ,i thought the batteries that came with the box were weak already,some times it happens,but after putting new batteries they drained in a couple days, in 30 days or so 4 batteries went dead ,
    what you thing about this?
    • 31134
    Re: Roku 4 remote batteries draining out?
    open it, check the electrolytic and the led
    and check the led with a camera - see if it's glowing slightly indicating a leaky drive transistor
    that or check the led pins wih a voltmeter to see if it's getting constant power
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      maybe worth asking on the roku forum aswell i know from reading people had this same issue with roku 3 remotes
      https://www.reddit.com/r/Roku/
      • ivtec
        • Dec 2008
        • 1967
        Thanks stj; but i just got this a month ago,i don't want to mess with it yet, i think i'm going to connect a 6 vdc adapter,i don't have to use it much cause my 2 R1 remotes do most the control job.
        • ivtec
          • Dec 2008
          • 1967
          thanks vinceroger69; yes i red that,some people say to have the remote upside down cause the sensor activates when move around the remote and i seat all the time very close to the remote control,it doesn't make sense but with roku4 nothing wonders me no more,and i only have this R4 for a month.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Can you contact Roku and get a replacement? There must be some sort of warranty on this thing!
            • ivtec
              • Dec 2008
              • 1967
              Hi guys; here some insight on the issue that most everybody that has gotten Roku 4 won't turn on unless unplug and re-plug from wall outlet,
              after some investigation i found out that it's not the R4 Unit to blame but we should blame it on the Remote control that after a a day or so drains the batteries and will not have enough strength to activate the unit,no wonder i could turn R4 with R1 remote control,anybody that owns R4 you don't need to return the box but rather return the remote control,which i don't think roku has a solution for it!
              • chargfox
                • Jun 2016
                There is a simple fix for most people with this issue. I threw a set away of batteries after one week. I almost threw away the second set. I had removed and reinserted them but they still didn't work. But then I "rolled" them over in the compartment and it came back on strong. The battery compartment is poorly designed and the batteries easily shift around. So before anyone throws another set of batteries out, first readjust them, attach a piece of foam to the inside of the battery cover so they cannot budge, and see if that's the issue.
                • mmartell
                  • Oct 2013
                  • 3189
                  How do batteries drain faster when not making contact ?
                  • chargfox
                    • Jun 2016
                    They don't. But unless you try them in another device or check the contact in the remote, they may not actually be drained.
                    I didn't know about this issue the first time and threw perfectly good batteries away after less than two weeks usage. I thought maybe I'd just used old batteries.
                    The next ones however were brand new and quit working in one week. After I removed and reinstalled them and they still didn't work, I prepared to toss them as well. But there was no way I was going to use something requiring weekly battery replacements and I went looking for the reason this was happening. Since I wasn't using headphones, I knew that wasn't the issue.
                    Then I found out about the loose compartment, so I put them in again but still couldn't get the remote to work. So I jiggled and rolled them around a bit to make sure, and as I started rolling them over, the remote came on.
                    I just cut a small piece of foam from my memory foam mattress topper and placed it under the cover and they don't move at all now.
                    It doesn't seem to affect all of the Roku remotes. My daughter got her hers at the same time and she's had no problems with it. Headphones draining the battery and the loose compartment losing connection are the issues most people are having with the batteries. I'm just happy that I didn't have to buy stock in Duracell.
                    • ivtec
                      • Dec 2008
                      • 1967
                      Thanks for this late info; but i have a fluke 87 DM and i always check batteries before i through them out,and in this case they were complete drained,and Roku Remote is bad.
                      • MaelstromGod
                        • Jul 2016
                        I'm going to find a way to contact Roku and let them know that I am going to modify my Roku 4 remote to include a micro USB port on the remote and a port on the ROKU 4 if necessary. Charging batteries separately and going through that process seems kind of an inconvenience and an oversight (either by accident or by design) by the engineers of ROKU. It was possibly on purpose that ROKU decided to not design a rechargeable high capacity battery option for cost of manufacturing or simplicity reasons. But I see a need for it as the always on call radio frequency and motion sensors and Headphone option draws immense amounts of energy from the standard Alkaline batteries.
                        As tons of reports come in that many ROKU users LOVE the responsiveness and low latency and omnidirectional field of operation that normal infrared remotes simply cannot match. Since the internal radio inside the remote is a 2 way (for the headphones mostly) that I'm sure it needs to be in a listening mode most of the time.
                        From an outsiders thought about the engineering aspect of the ROKU: I believe that the ROKU design was with the remote being in the center of the experience. Simplicity and built in functionality. It seems their goal was a visceral and texture based experience. Eyes to hands. I personally love the crisp responsive experience but at the cost of replacing batteries so often, it is worth the effort to modify the setup to make an already great experience better.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          The Roku remote is constantly trying to 'pair-up'....so batteries drain quickly....ask for a new set-up from the Supplier....don't open it or try to fix it....
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            You're not leaving any headphones plugged in are you ?
                            • carrzkiss
                              Cyberpower cps1500avr not charging batteries
                              by carrzkiss
                              Hello, all.
                              Cyberpower Battery Backup Unit.
                              I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                              When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                              In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                              Checking the voltage, it was down to 22v.
                              I quickly removed everything...
                              06-15-2024, 02:10 PM
                            • howardc64
                              Where do repair shops buy MB replacement batteries?
                              by howardc64
                              Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                              Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                              BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                              07-25-2024, 10:42 AM
                            • Astonished
                              Fixing the Charge Circuit of the Batteries of the DC Motor
                              by Astonished
                              Hi friends of electronics
                              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                              Please help me fix this circuit.
                              (the datasheet of the IC: https://pdf.datasheet.live/28...
                              01-28-2025, 06:24 AM
                            • edugimeno
                              HiSense 55A7500F won't obbey to remote after power on
                              by edugimeno
                              Hi! I have this TV set that does the following:
                              1) I press the red power button on the remote
                              2) The TV turns on normally
                              3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                              4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                              Then after it's off, it would again accept the TURN ON from the remote and same again
                              BUT:
                              -The remote does show the correct IR beam while observed thru a phone camera
                              -The TV works fine while using the MiRemote...
                              03-14-2023, 11:22 AM
                            • rustinjust
                              Please help, where can I get a remote for my subwoofer?
                              by rustinjust
                              I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                              Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                              Is there...
                              10-28-2023, 03:43 AM
