Color Cells CC784 Repair & Restoration Log
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Recently im looking into building my own Led sign board. Wanted to get familiar with them before launching into a project, so picked this up off ebay for £20 delivered ! The guy selling it was down the road from me This unit is the Colour Cells CC784 Programmable Led Signboard, a very interesting one to. Its based off a shift register design with MC1413P Ics to select the Leds made in about 1989 so quite old. Comes with a remote which has letters on that you can type and programme for the display.
    This unit however needs some minor repair, the unit when powered off the memory seems to corrupt and forgets what has been written to the display and acts like its from factory. I have not yet opened it to diagnose but will have a look soon looks like it has a memory battery so probably just needs changing. I will also be restoring and replacing every Led in it with brand new ones to help the reliably of the unit.
    TBC
    • 31087
    Re: Color Cells CC784 Repair & Restoration Log
    fixed those!
    get that bitch open fast and bin the nicad battery.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Deffo mate just waiting on someone to pick a Tv up What failure did yours have ?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Lol have a look at this bodge repair job didnt even bother to replace the corroded diode and resistor
        • Spork Schivago
          • Mar 2012
          • 4734
          • United States of America
          TBC
          Wow, that's cool. We have this signs by the road that are portable. The city puts them up to give us messages, like Road Closed December 12th - 24th for repairs. Or Watch out for pedestrians! I've always wanted to learn how they put the messages on them and sneak down at night one night and add 2600 or something to the one of the messages. A lot of times they'll have a few screens worth of messages. Like display one message for so many seconds, then display another. I wouldn't erase the original messages, just add a new one that says 2600. I thought that'd be great.
          -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
          • Spork Schivago
            • Mar 2012
            • 4734
            Wow, look at all those ICs. That thing is cool as hell man. Wish I could find one for 20$.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yeah man Interesting stuff this is, very well designed for a device this old. Newer types if Led sign boards use Led controllers which are less complex but work just as well and can control alot more Leds.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Yep the Ic's are the supporting Epproms for the shift Ics then there is a further stage of decoupling for them. Getting a parts list together to restore this thing The guy attempted a repair but didnt fix the failed parts so im going to now, needs a 3.7v 300mha battery for it better get looking
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Originally posted by stj
                  fixed those!
                  What battery is used buddy you got a part number ? So far I know its a 3.7v 300mha but not too sure.
                    • 31087
                    3cell pile of shit - dont worry about it.
                    you need to clean the corrosion by throwing vinegar all over it,
                    then remove the charge resistor in parallel with the diode from the battery and fit a cr2032 coincell holder.
                    lithium coincells are more reliable.
                    oh - i dont think i need to say what i needed to fix in them!
                    if they are real bad, you have to lift and replace chipsockets!
                      • 31087
                      btw, once it works you'l love the animated shit like the steam engine!!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Nice one, so remove the resistor and diode, then install a cr2032 socket and battery guessing that the diode and resistor that charge the previous battery? Also removed them chips before and the sockets are corroded so got to clean them as well as the pins on the Ic's.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Just to be sure, is this the diode and resistor you mean ?
                            • 31087
                            the diode and resistor are inline with the battery,
                            the diode stops the battery getting hit with 5v when it's running,
                            the resistor bleeds some power across the diode to charge the battery.
                            you must have the diode inline with the battery to prevent it getting destroyed by 5v,
                            but you remove the resistor to prevent it being recharged.
                            diode should be a schottky to minimise the voltdrop btw, the battery will be 3v and the ram is rated down to 2v from what i remember.
                              • 31087
                              lol your foto shows they put the diode and resistor in each others places!
                              they should lead to the battery + terminal
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                I see the ones you mean now, the resistor is at the top here and the diode is at the bottom. So remove the resistor when adding the CR2032 socket ?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Doh ! Hey im tired haha
                                  • Robo129
                                    • Jul 2018
                                    I am no rocket scientist or hardly know anything about electronics but am attempting this fix. Do you mean remove both resister and diode. How many CR 2032 batteries will I need to replace the others. Can you please post exactly step by step as to what I have to do. Appreciate immensely. Bob
                                      • 31087
                                      just remove the resistor,
                                      and use a single cr2032 battery.
                                      • Sheeshbajeesh
                                        • Nov 2021
                                        • 7
                                        I'm working on removing the NICAD from mine as well and doing this battery mod. The resister to be removed is R4 on the main board, correct?
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • Chaks
                                          The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                                          by Chaks
                                          I need help to extend the runtime of the ups board (see attached image).
                                          This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                                          Thanks and kind regards,
                                          chaksindia...
                                          01-21-2025, 11:39 AM
                                        • pc_okay
                                          Xerox Versalink C505 bad printing in color mdoe
                                          by pc_okay
                                          Hello friends,
                                          I have a problem with this printer Xerox Versalink C505 , printing perfectly in B&W but bad in color.
                                          There is a little yellow ghost printing around color print.
                                          So little text in color is unreadable.
                                          I already change drum cyan & yellow with no success.
                                          I try (i think) all avalable calibration in printer menu..
                                          (black drum is dead but it's not the problem i think)
                                          I'm not a printer specialist,if anyone has an idea?
                                          Thanks !...
                                          12-01-2024, 09:08 AM
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
                                          HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-06-2024, 08:23 AM
