Need help reading a schematic.
    • 30917
    Re: Need help reading a schematic.
    you dont need flux to desolder with hot air if you can see the pins.
    BGA is a completely different situation, your using the flux to transfer the heat under the package.
    using a nitrogen gas-flow system would be better, but seriously expensive!
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #122
      Originally posted by keeney123
      The flux is to transfer the heat from the iron to the solder joint. It allow a even flow through the joint and helps to get rid of oxygen in the joint. If you have no flux in your solder, flux will be needed to unsolder a joint with a solder iron. With a hot air gun, I do not know. I would think the flux would aid in a uniform heat. You do not need a lot of flux. With Surface Mounted Components they usually use a small flux bottle that has needle is attached and use just enough to wet the pads. This would be a liquid not a paste. I would think paste would be messy and harder to control.
      I got flux in that needle / syringe type thing but I also have solder paste. It's silver in colour. I "paint" it on the pads / terminals and when I heat it up, it melts into a silverish type solder. It's actually kinda cool and is real good for SMD components. Just that the only time I've successfully used it was when I had a stencil for the component. Just can't seem to judge how much paste to use.
      Thanks for the info on the flux. I remember reading something about it having to do with providing a nice clean joint. I too thought that it would help in providing uniform heat, when it came to removing stuff, specially BGA type components.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • Spork Schivago
        • Mar 2012
        • 4734
        #123
        Oh! That's where my mistake was! Watching the videos on the BGA and just assuming the flux was the same for SMD components! Duh! Man, wish I had a nitrogen gas-flow system. Also wish I had one of those nitrogen systems for wine. My wife likes wine but doesn't drink it very often. The reds tend to turn a bit vinegar-e-ish if they're not drank quick enough. Friend of mine works at a country club (a real fancy one for rich people) and he says there, they have a nitrogen system that replaces the air in the bottles with nitrogen so it doesn't turn. I guess even for the wine bottles, they're real expensive!
          • 30917
          red wine - mmmmm...
          after 24hours is good, after 48 it starts to go downhill.
          just kill the bottle the first day - problem solved.
          • Spork Schivago
            • Mar 2012
            • 4734
            #125
            red wine - mmmmm...
            Yeah, never really meant anyone like my wife before. She'll pour a glass of wine and just drink a 1/4 or maybe 1/2 a glass and just leave the rest. When I used to drink, I always drank until I couldn't drink anymore. I drank on a daily basis for a while there. Once Jess and I found each other though, I gave all that stuff up.
            • Spork Schivago
              • Mar 2012
              • 4734
              #126
              So, what do you think of the solder job using solder paste and a hot air rework station? I think it isn't too shabby. I had a little trouble. The only problem was trying not to put too much paste on the pads. I had to wipe it off once or twice because too much came out. I checked every resistor to make sure there were no shorts or anything. Everything tested good. Two of the resistors ended up lifting off the board and staying straight up in and down instead of laying flat on the board. But I just used a pair of tweezers to push it back down.
              The preheater really seems to be the key for this stuff. Using the preheater, it only took a few seconds for the solder paste to melt and turn into solder. I used a low air speed, 3 on my system and a temp of around 650F or so.
                • 30917
                pretty good,
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #128
                  pretty good,
                  Thanks! First time I've successfully used the hot air rework station to actually solder something. It's great for removing stuff. Glad I didn't have much problems.
                  On a side note, when I clip the leads off the through-hole UV LEDs, the wire snippers I use cut the leads leave them a bit smushy looking. They definitely don't look like a professionally done PCB. Is there a better way to cut these leads? How do they do it at the factories?
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #129
                    So the power supply powers the UV Exposure Time circuit board, which powers the UV LEDs. The power supply should have a fuse in it I'm thinking but is it possible that the power supply would break in such a way where it could fry the exposure time circuit board? Would it be a good idea to add a fuse to that circuit board or don't power supplies usually break like that?
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #130
                      Man, I had a scare! Took me a bit to figure it out. Soldered all the UV LEDs on the board and one whole column (four UV LEDs) didn't light up at all! I thought for sure it was the trace. I went through and touched a soldering iron to each one, hoping it was a cold solder joint or something. No go. I looked at the schematic and board layout and studied how the lights were actually ran for those four non-working UV LEDs.
                      Then I went back in the work room and tried putting the ground on my PSU to the ground lead on one of the non-working UV LEDs. This got most of them working, except one. But the three that lit up weren't very bright. I started looking at the one that wasn't lit up and realized I put it in backwards! If I had cut the leads off the LEDs before testing it, I probably wouldn't of figured this out as easy like! Works like a charm now.
                      I went back through and checked the other two boards that I had already finished to make sure all of them actually lit up. One of them is different though. I even remember when I soldering, one UV LED had much longer leads. I want to say it's the same UV LED. It looks like maybe someone else made it. All the other ones glow the same colour but this one is much deeper in colour. Would this make a difference when I go to transfer the picture to the PCBs? Should I replace it with another UV LED? Thanks!
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        So with the needle and the flux it is easy to use. Just small amount on the pad and solder. With the right tip on the iron one just puts some solder in the tip and just pull it down on the edge of the component leg. One pin after another without stopping. Just add a little solder when it get used up. If for some reason a solder short appears then apply flux and heat up. The solder will go to the pads. A good solder joint on Surface Mount will be on the outside edges of the leg of the component. So it will be from the edge of the component leg to the pad on three sides of the component leg. This is easily accomplish with a hoofer tip or a bent beveled tip that is about the size of the leg being solder. Should be able to solder a 14 pin IC in a matter of seconds.
                          • 30917
                          your cutters are making that look, get a pair with a flush-blade on the outer edge.
                          factory's used to use a saw to trim all the leads years ago,
                          now the leads are pre-cut before they are auto-inserted.
                          you can see this with some of the ebay chinese cap sellers who are selling surplus from production-lines.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #133
                            I've seen this method done in videos but when I try I mess up horrible! I tip my hat to anyone that can do it that way. It's simply amazing! My hands shake pretty bad sometimes. Usually it isn't that noticeable until I work on smaller stuff. That makes it a bit harder. Eye sight isn't great either so I usually use a magnifying glass while I'm soldering.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #134
                              Okay. Could you link me to the type of cutters you're talking about? Thanks!
                                • 30917
                                cant find a good foto, but you want a pair where the blade is ground on the inside only.
                                they are usually called "flush cutters"
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #136
                                  Thanks! Like these? http://www.all-spec.com/products/801...FUgXHwodAlwOoA
                                  I'm currently uses these from Radio Shack:
                                  https://www.radioshack.com/products/...ant=5717833157
                                  They're okay for cutting wires but for leads, they just more or less smush the metal. Maybe it's because they're not sharp enough?
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #137
                                    I just burned myself on this Weller! It's the first time on this iron! 650 degrees F (around 343 C). It left a nice white mark on my finger where the iron touched. It's about 1/4" (6 - 7 mm) long. Boy does it hurt!
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      I did not know that. Anyway, you found a way that works for you and there is nothing wrong with that.
                                        • 30917
                                        343' seems high, i solder at 310' with lead-free solder.
                                          • 30917
                                          that's the type.
                                          • waigy
                                            Variable resistor potentiometer has different reading when mounted on the board
                                            by waigy
                                            In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                            I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                            The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                            I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                            I then took the pot out the board and it now measured 22k.
                                            I tried putting it back in the board and it goes back to 10k.
                                            Is this normal and if so what pot should I order?
                                            On this...
                                            11-12-2024, 04:44 AM
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • atunguyd
                                            Acer x163w Monitor PSU schematic
                                            by atunguyd
                                            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                            03-05-2025, 02:08 PM
