Need help reading a schematic.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #61
    Re: Need help reading a schematic.
    I understand about the electromagnet thing. I read an article about that. Some state regulation or something. Some states, they're supposed to have odds of one out of twelve, other states, one out of fifteen. I guess they have 4-6 PSI on normal tries, it takes around 10 PSI to grab a toy. On the nth time, the PSI increases. If they don't win on an increased PSI try, the odds get better or something. But in this laundromat, the actual arm had screws. I would go in and win on a regular basis. One day, I went in, and the owner or someone actually loosened the screws so the arms where wobbly. There were cameras and everything. I played once, noticed how loose it was, I shook my head and stopped playing. When ever I won, I'd just leave the toy on the counter for children. A week or so later, I came back, they were tightened again. It could've been that he didn't know how to program the control system or it could also be that the screws just came loose on their own.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • 31283
      probably he didnt know how to control it so he just screwed it up and then fixed it after it became obvious.
      • Spork Schivago
        • Mar 2012
        • 4734
        #63
        Yeah. I know some of the people that worked there (I believe it was family owned / operated) didn't speak English at all. So it's very possible the family member in charge of the Crane Machine couldn't read the english instructions on how to set the odds. Thanks for pointing out the PSI thing. That was a nice read and something I didn't know!
          • 31283
          some of the best come from here:
          http://elaut.com/amusement/Belgium/index.php
          • Spork Schivago
            • Mar 2012
            • 4734
            #65
            I want this one! http://elaut.com/amusement/Belgium/g...cketCircus.php
              • 31283
              you must have a lot of space!!
                • 31283
                manual for your learning.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #68
                  Oh cool, thanks! We don't have a lot of room. Two bedroom, one was turned into a work room. But I'd like to own a house one of these days. A two floor house would be nice, with an arcade / video game room. I could own a bunch of the old consoles and even some of the new. Hook them all up to a TV using some sort of fancy setup. Mabe even have a pinball machine or two, a soda machine and maybe even one of those coin changer do-dads.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #69
                    So, I now want to modify the circuit and replace some of the components with SMD versions. For example, R2 is a 16 ohm resistor. I know wattage = voltage * amperage. But how can I tell what's the smallest wattage surface mount resistor that can safely be used as a replacement for the R2 resistor there? I believe the through-hole one is a 1/4 watt resistor but do I need to use a 1/4 watt SMD resistor? Thanks.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #70
                      Would I use something like P = (v * v) / R? Where V would be the 5V that goes to the resistor, R = 16 ohm, which is the resistance of the resistor.
                      Something like:
                      P = (V * V) / R
                      P = (5 * 5) / 16
                      P = 25 / 16
                      P = 1.5625
                      I read that I should double that value when using SMD resistors, so
                      P = 3.125. That can't be right at all! What am I doing wrong here?
                      The current going through that resistor would be 0.3125 amps, right? Using I = V / R, I = 5 / 16, I = 0.3125.
                        • 31283
                        what's this about?
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #72
                          The original schematic I posted on page 1, the PDF. I'd like to replace the through hole resistors with SMD resistors but I'm not 100% sure how to calculate what the power rating for the SMD resistors need to be. Ie, do they need to be 1/16th of a watt, an 1/8th of a watt, a 1/4 of a watt, etc. The through-hole one, R2, is an 1/4 of a watt through hole. But how do I calculate what's the smallest wattage SMD resistor I can use in replace of the through hole 16 ohm through-hole resistor.
                          • redwire
                            • 3912
                            You can calculate a resistor's power dissipation two ways- knowing voltage across it, or knowing current flow.
                            For resistor R2, it does not have 5V across it because the LCD backlight uses some. Check the LCD datasheet, it might be 3.2V say depending on color/size. You can also read the backlight current rating.
                            So R2 sees (5-3.2V)/16=0.20W (as an example)
                            Good practice is to use a part at ~2/3 of its rating. Why? Resistors are usually rated at 70°C/170°F which is a bit hot for long life.
                            To dissipate heat, physical size is all that matters and SMD resistors still need to be fairly big. Get your backlight numbers and try the math. You can also use two (SMD) resistors together and double the power handling.
                              • 31283
                              R2 would depend on the display, modern displays can use a single high-eficiency led with a good light-pipe,
                              older ones could use anything from 2 to 10 or more - specially if they are actually "back" lit..
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #75
                                Thank you RedWire! So my math formulas were straight up wrong then? I used the magic circle. Was I calculating how much wattage the device was using instead of how much power it was actually dissipating? I know my numbers were wrong and what you said make sense except for the formula. I thought V / R = I. I thought wattage was found using something like:
                                V * I = P
                                V^2 / R = P
                                I^2 * R = P
                                The schematics say it's an HD44780 for the LCD display, but for some reason, what I got was a BC1602A ( ) It's supposed to be blue in colour but I haven't had a chance to actually power it on yet to check. Still gotta finish soldering all the UV LEDs.
                                If I'm reading the datasheet correctly, current for the backlight would be typically 20mA, right? For the backlighting voltage, it's using 3.5V for the blue type screen, right?
                                So V / R = P (I thought V / R == current, not watts)
                                5 - 3.5 = 1.5V
                                1.5V / 16 ohm = 0.09375 Watts
                                Then I just want to take 2/3s of 0.09375 watts.
                                0.09375 watts * (2 / 3) = 0.0625 watts
                                0.0625 as a fraction would be 1/16th, so I could safely use a 1/16th watt 16 ohm resistor or I could safely use two 1/32th watt 8 ohm resistors, in series?
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #76
                                  No, no, not the resistance. I want to know how to calculate the smallest wattage resistor I can safely use. IE, is an 1/8th watt 16 ohm resistor the smallest wattage resistor, or is 1/16th watt 16 ohm or 1/32th watt 16 ohm. I want to use SMD resistors but I see a lot of SMD resistors that are small wattage, like 1/16th seems common, but there's also 1/32th of a watt. Most through holes I see are always 1/8th watt or usually they're a 1/4 of a watt. Never smaller.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #77
                                    Redwire,
                                    Google says this about finding a resistors power dissipation (I didn't know what I was looking for was called power dissipation, thank you!)
                                    First, we use Ohm's law ( V = I x R ), to find the current through the resistor. The voltage across the resistor is V = 9 V. The resistance of the resistor is R = 100 Ω. Then, we can use the power rule ( P = I x V ), to find the power dissipated by the resistor.
                                    The current the back light uses is 20mA though, so can I just use P = 20mA x 1.5V? Or P = 0.02A * 1.5V
                                    P = 0.03 Watts
                                    0.03 * (2 / 3) = 0.02 Watts
                                    0.02 as a fraction would be 1 /50th. That just seems reeeally small! I guess I'm still confused here.
                                    • redwire
                                      • 3912
                                      The Ohm's Law formula you use depends on what numbers you know. (I might have forgotten the E squared in my post, sorry if that confused).
                                      Two ways to do it, look at voltage across the resistor or current through the resistor.
                                      Applying Ohm's Law: P= I^2*R or P=E^2/R
                                      For your LCD display:
                                      White/Blue backlight likes 20mA and about 3.4V: (probably 1 LED)
                                      R2= E/I = (5-3.4)/20mA = 80 ohms
                                      P= I^2*R = 20mA^2*80 = 32mW
                                      LED power P= E*I = 3.4V*20mA = 68mW
                                      Yellow-Green backlight likes 100mA and about 4.2V: (probably 10 LED's)
                                      R2= E/I = (5-4.2)/100mA = 8 ohms
                                      P= I^2*R = 100mA^2*8 = 80mW
                                      LED power P= E*I = 4.2V*100mA = 420mW
                                      SMD 1206 is rated 250mW or 167mW derated by 2/3
                                      SMD 0805 is rated 125mW or 83mW derated by 2/3
                                      SMD 0603 is rated 100mW or 67mW derated by 2/3
                                      I'd use an 0805. They aren't super small like pepper flakes.
                                      A (more modern) low power backlight also means the voltage regulators will run much cooler.
                                      Maybe voltage drops are confusing you. Start with power 5V and then subtract the two voltage drops (across R2 and then backlight LED) and then you hit zero 0V (GND).
                                        • 31283
                                        HD44780 is the interface, originally it was the part number of the chip but they are cloned to hell now.
                                        BC1602A is the display that is using the chip - part number suggests 16characters by 2 lines, A is probably related to led colour or viewing angle.
                                        • Spork Schivago
                                          • Mar 2012
                                          • 4734
                                          #80
                                          Yeah, the missing squared was throwing me off! I was looking at my circle and just kept on seeing I = V / R. Now that I know you was definitely using the power formula (wattage), it all makes sense! I do struggle a little with the voltage drops some times but I'm getting better. I'm okay when it's just one device and I'm calculating the voltage drop across that device, but I seem to struggle when there's more than one device.
                                          Also, the guy originally used a 16 ohm resistor but if I really understand this, with the white / blue background, I should be using an 80 ohm resistor? Because the Voltage / Current shows us the resistance is 80 ohm. Or am I misunderstanding that too?
                                          Eventually, I want to replace the LCD screen with a touch screen QVGA LCD type screen. Thanks for all the help and showing me how to figure that out!
                                          • waigy
                                            Variable resistor potentiometer has different reading when mounted on the board
                                            by waigy
                                            In my fusion FE-402 car amplifier the gain pot is an RK097G.
                                            I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
                                            The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
                                            I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
                                            I then took the pot out the board and it now measured 22k.
                                            I tried putting it back in the board and it goes back to 10k.
                                            Is this normal and if so what pot should I order?
                                            On this...
                                            11-12-2024, 04:44 AM
                                          • DeanWy
                                            WD Sentinel DS5100 (NAS) boot issues
                                            by DeanWy
                                            I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                            It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                            There...
                                            07-30-2024, 04:13 AM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • atunguyd
                                            Acer x163w Monitor PSU schematic
                                            by atunguyd
                                            Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                            The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                            03-05-2025, 02:08 PM
