Random ponder: Why LEDs aren't used as pixels?
  • caphair
    • Nov 2011
    • 1249
    Random curiosity but why can't they make a tv using leds as individual pixels with color filters for rgb like they do in oleds? Is it bc with oleds they can make them really small due to the material?
    • 31139
    Re: Random ponder: Why LEDs aren't used as pixels?
    they tried, too much heat in a small area was killing the organic led material.
    you can get them upto 12inch - maybe a bit bigger in japan, but they have limited lifespan.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      If each LED drew 500 microamps, and you had a 1024x768 RGB display, you'd be drawing 1200 amperes when the screen was all white...
      • caphair
        • Nov 2011
        • 1249
        Yikes. So what makes organic LEDs more efficient in terms of current draw?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Yes lol even still 55" Oled tvs have a 24v 10amp rail going to the display ! Thats 240w right there.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I'm probably being very pessimistic at 500microamps however, as the LED pixels probably would be smaller than 1mm x 1mm (then again, not for the large OLED display...)
            I think it's more of the manufacturing costs needed to make regular LEDs compared to OLEDs that makes the latter feasible.
              • 31139
              oleds are killed by heat.
              current for a panel wont be too bad though because it will be a scanned matrix not a direct-drive scenario.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Yep like Lcd basically, not like good old Plasma. I expected it to be similar to Plasma in the drive method however just like Lcd so I expect panel failures to be quite high after a few years tbh.
                  • 31139
                  you can screenburn OLED, i'v seen it on a galaxy tab fone!
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    I have as well check this out:
                    https://www.badcaps.net/forum/showthread.php?t=43951
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      They are nice displays very good image best ive ever seen ! The reliability of them is questionable though.
                      • caphair
                        • Nov 2011
                        • 1249
                        How is it they can "print" oleds? Read that somewhere. Is it because of the "organic" materials used as oppose to solid minerals in LEDs?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Possibly even im not too sure better get researching :L
                          • mariushm
                            • May 2011
                            • 3799
                            To answer the random ponder...
                            Some displays have a larger red compared to green and blue because eyes have different sensitivity, see for example the superAMOLED from Samsung: http://zeptobars.ru/en/read/Samsung-...Galaxy-S4-mini
                            Just the same, with LED displays you'd have two different led sizes
                            Then, there's an issue with grayscale and brightness in general. To get a reasonable contrast and brightness, you'd need about 12 bits at least, so that's some pwm'ing of each led, a lot of fluctuations in the power consumption..
                            Then, you have the issue of binning all leds in the panel, you'd have to measure the light output of each led and measure the candela rating (or whatever is the proper unit of measurement), then age the leds for a few hours and measure them again and throw away the ones with too much difference.
                            It's not practical. For example, people making advertising panels just split everything in chunks of 32x32 or something like that, measure the brightness and store some data in an eeprom .. then a few of those are connected to a board with a big fpga which reads the eeproms of each small unit and then converts each pixel to a new value based on the information in those eeproms.
                            Here's a very informative video about this : https://www.youtube.com/watch?v=6iHTbGsnI8Q - imagine all the electronics and all that high speed data in the back of the monitor, and imagine the heat generated and the heatsinks required.
                            • caphair
                              • Nov 2011
                              • 1249
                              So what makes oleds different for use in tvs if they work the same as LEDs, is it because the material makes it more practical for screens?
                              I'm also curious how burn occurs with oleds, do they glow that intense that the phosphor used for rgb burns in?
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Burnin works the same as LEDs, LEDs will also dim with age. Same with all displays, the light emitting source will go down.
                                Except that with backlight displays, the backlight/frontlight can be replaced. Also you don't notice as much because the backlights/frontlight dim everything at the same rate.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Ok but I'm still confused how burn in occurs with LEDs/oleds if phosphor isn't used?
                                    • 31139
                                    heat breaks down the chemical that emits the light.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Its an organic material not Phosphor ! Being organic the heat and energy will cause it to fatigue over time.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Ok so heat breaks it down to where it doesn't emit as much light as it did and this causes shadows of previous images to show?
