re:... X1EA smd
  • comptek
    • Aug 2013
    • 606
    • uk
    re:... X1EA smd
    hi does anyone know what this is i think its a sot23 package on it is (x1ea)
    and or equiv please
    many thanks
    Gary
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: ... X1EA smd
    Its a transistor buddy. Will get data-sheet
    • comptek
      • Aug 2013
      • 606
      • uk
      Re: ... X1EA smd
      thanks Reece
      • comptek
        • Aug 2013
        • 606
        • uk
        Re: ... X1EA smd
        its ok Reecey.b
        sorted i found something like it on another board i have the screen back now just need sound sorting its a b.spc82b board out of a Akura APLDVD21621W-HDID cant find a circuit diagram for it anywhere
        • redwire
          • Dec 2010
          • 3912
          Re: ... X1EA smd
          I show that as a AO3401A P-ch MOSFET.
          http://www.aosmd.com/search?pn=AO3401
          Click on part number, then scroll down to marking to get the code.
          • comptek
            • Aug 2013
            • 606
            • uk
            Re: ... X1EA smd
            thanks Red its sorted now but the info is very handy thank you
            • Nevillet
              Identifying a 'FS45' SOT23 device
              by Nevillet
              Hi All,
              I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
              Its named FS45 but I can't find a datasheet that seems correct.
              The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
              Can anyone identify the device and suggest an alternative?
              Many thanks.
              PS: I have...
              06-19-2024, 11:42 AM
            • mecmast
              Need help about "G2920T11U" / "G2990" / "2990(x) SMD SOT23-5 replacement
              by mecmast
              I've searched the internet but couldn't flnd a replacement/substitute for this part.
              It is marking as "2920N" SOT23-5 case.
              I am looking for the "G2920T11U" 3.3v version.
              Also uploading the datasheet.
              Thank you all....
              10-15-2025, 11:39 AM
            • kjchatman
              identifying sot23 on backlight cirucuit of 17" razer rz09-0423
              by kjchatman
              this laptop was damaged by a roof leak at the repair shop that it was at while waiting for a replacement cpu fan. It was given to me to try to save the motherboard which wouldn't power up anymore. The only issue now is that an sot23 marked R1 is missing one of it's three legs. I cannot find schematics for this model but I found a mosfet that has the same label but i'm not sure if it's an actual match. CJ3401 is the one that I found but I have no clue about the true identity of the damaged one.
              07-28-2025, 11:47 AM
            • eccerr0r
              SOT23-5 LiFePO4 protection IC? 13D1S?
              by eccerr0r
              I have a SOT23-5 marked
              "13D1 S"
              I wonder if anyone recognizes this IC? It should be a LiFePO4 protection IC, but having problems finding the datasheet, anyone recognize this?
              G00gl3 returns a 6-pin LDO which is not quite right...
              05-14-2025, 10:41 AM
            • dicky96
              SMD code ADSH & F1FD sot23-5 identify?
              by dicky96
              Hi guys
              These devices are in some MAG250 IPTV boxes near the power input
              I have several faulty ones but they are not all identical
              On several I have an SOT23-5 device marked ADSH. Working anti-clockwise from the dot, Pin 2 is ground and pin 6 is 3.3V supply input. Pin 5 is missing of course
              On one other I have an SOT23-5 device marked F1HD in the same location but the PCB track layout is different (there are also some extra resistors/capacitors in this area). This one has Pin 1 & 2 ground (I can see they are connected to the same track on the PCB)...
              02-15-2022, 07:23 AM
