Help needed with ribbon ZIFs (metal frames)
  • ajthatch
    • Feb 2013
    • 3
    I am familiar with ZIF plastic flip-up tabs but these are metal and not so obvious to me. How do I open these?
  • rakesh.hc
    • Jun 2015
    • India
    Re: Help needed with ribbon ZIFs (metal frames)
    You just need to flip open the brown colored viewing it from top,use fine flat tweezers to flip open & do it cautiously do not apply more pressure as you might end up break the connector tab/lock.
    You could also use a good magnifier to understand how this could open,it's only mechanical.
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • silver60618
      How to clean Liquid Metal from under CPU?
      by silver60618
      Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
      The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
      Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
      07-11-2025, 01:47 PM
    • Rubenlily
      Quick question about the ribbon
      by Rubenlily
      Hey,
      So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
      When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
      08-17-2023, 11:09 AM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
