Light Fixture UK Overloaded 240v to 12v
  • anotherdude
    • Feb 2013
    • 488
    So a few bulbs had blown a while ago in this rather expensive light fixture, I bought new bulbs (16w) and put them in all was great until later that night when it suddenly completely turned off.
    Having looked at the light again it has stickers next to each bulb socket stating 10w so i'm assuming it's just overloaded, the light has space for 6 bulbs at 10w each.
    So i'd replaced 4 bulbs with 16w ones so it was using 2x10w and 4x16w when it went off, when really it should of only had 6x10w resulting in 60w, instead it had 84w, so I can only assume this was the problem.
    Rather than bin it I thought i'd ask here if anyone can provide any help on diagnosing the faulty part, it converts the 240v to 12v.
    Haven't taken any readings from it yet as it's been removed and been replaced, i'm hoping it's just a fuse somewhere but no idea what really to look for.
    Any help is greatly appreciated.
    • 31283
    Re: Light Fixture UK Overloaded 240v to 12v
    look closely at the soldering, some joints are cracked.
      • 31283
      without even trying - i see these.
      • anotherdude
        • Feb 2013
        • 488
        Resoldered all points, still the same
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Why did i think you were trying to fix a fluorescent ballast?
          Im going back to bed......
          Follow the white rabbit.
            Are the lamps Halogen 12V Lamps/ It looks like a simple 12VAC output high frequency switcher.
              Can you zoom in so the whole board will show without seeing the table? Make sure they are in focus also.
                BTW, the fusible resistor and the Thermistor are OK?
                There two power devices strapped to the heatsinks, did you check them out?
                • anotherdude
                  • Feb 2013
                  • 488
                  yep halogen 12v, will get more pictures later today
                  • anotherdude
                    • Feb 2013
                    • 488
                    No visible damage, will check what you said
                    Heres more pictures best I could do
                    Fusible resistor checks out fine
                    R2 on the back of the board looks damaged looking at it again, camera is playing up will try get more
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5086
                      • New Zealand
                      Probably you'll find something has gone open-circuit.
                      -David VanHorn
                        Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                        by sam_sam_sam
                        So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                        The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                        You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                        09-07-2024, 07:26 PM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                        LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 03:40 AM
                        LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                        This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 09:10 PM
                        09-06-2024, 08:40 PM
