Logic latch circuits for relay drivers?
  • Maxxarcade
    • Jul 2006
    • 973
    I want to build a source/output selector box, like they use at department stores, that you press a button to pick which stereo or set of speakers you want to listen to.
    I was planning on using several SPDT relays, connected to a logic circuit with momentary pushbuttons, that would activate and hold whichever relay corresponds to that switch.
    Are there any pre-made buffer/driver IC's that would serve this function? Or am I going to have to use individual IC's wired together? It can't be too hard to do this.
    Another way would be to use ganged rotary switches, but those are a pain to work with.
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Logic latch circuits for relay drivers?
    Well, I found this:
    http://www.aaroncake.net/forum/topic.asp?TOPIC_ID=6356
    Looks like what I need... Any ideas?
    • shadow
      • Feb 2007
      • 732
      What you are trying to do is to have a bunch of switches and depending on the switch that you press, the appropriate output device is chosen. In other words, you have one input and multiple outputs. Is this correct?
      If so, then the job sounds easy with an electronic device known as a De-Multiplexer. There are heaps of these things around for probably fairly small prices. You will probably need a few Flip-Flops if you want to use momentary push buttons rather than the permanent type. Flip-Flops would be needed to latch the logic value from a particular switch. Then you will probably need a small logic gate circuit connecting all the buttons with the appropriate select signal needed on the De-Multiplexer.
      Does that give you any good ideas? I just realised that the main problem with this approach is that this is a digital circuit. It really is not designed to work with analogue signals like sound from a radio or cd-player. The way to fix this up is to not use a De-Multiplexer but use either a Relay or a Solid State Relay. The rest of the circuit would largely be unchanged.
      • Maxxarcade
        • Jul 2006
        • 973
        Correct, mostly. I'll be using relays to couple the signals, I just don't know how to make the circuit to drive the relays.
        There will probably be several inputs and outputs. Basically I have several different receivers, and several pairs of speakers. I want to be able to pick between a combination to listen to without patching cables around.
        The rules for operation are, only one input (receiver/amp) can be on at a time, but up to two outputs (speakers) can be on at a time.
        I'll worry about the output side of things myself, I just need help making a logic circuit that takes a momentary input, turns on its respective output, and latches it on until another switch is pressed. I will use switching transistors to allow the logic circuit to drive the relay coils.
        • shadow
          • Feb 2007
          • 732
          I will work something out for you, however what I am thinking about at the moment is to use D type Flip-Flops to act as a suitable latch for the buttons.
          EDIT: I wish I had a circuit drawing program!
          • andrew77
            • Jan 2008
            • 81
            Try this program out that I found. Probably be pretty decent to work out some logic circuits with.
            http://sol.gfxile.net/atanua.html
            It's someone's project for school. He's been updating it daily, also. I think he wants feedback so he can make a good grade.
            • starfury1
              • May 2006
              • 1256
              Well your still probably going to have to do some sort of circuit work
              but I found these to give you an idea
              http://www.maxim-ic.com/appnotes.cfm...te_number/3224
              https://cdn.badcaps-static.com/pdfs/...c1b601a718.pdf
              By the sounds of it you want one Input selected only but the possibility of 2 outputs.
              I take it you actually switching the power amp outputs of the receivers to separate speaker pairs
              The ic's them selfs maybe pricey and perhaps as shadow said using some cheap type flip flops with an *"interface "for the relay switching might be a cheaper way to go.
              (* transistor etc on coil)
              what would add to the complexity is if you want to make it "idiot proof" by only have 2 output relays connected at one time.
              especially if you are switching power amp outputs
              (which may introduce another set of problems)
              Side point
              If your were talking about line level type signals there are things known as bilateral switchers
              (they do have some resistance and I don't think they are great for audio, thought I do vaguely remember them bing used in this application but not totally sure on that)
              I suppose something like this maybe commercially available but would probably cost...I guess Hi Fi stores would have this type of thing.
              I know there use to be switch box things available from places like radio shite but I think they were just a big switch anyway.
              hers a simple AB switch I found over at RE's ESP site
              http://sound.westhost.com/absw.htm
              Main page
              http://sound.westhost.com/index.html
              its a doable thing just a matter of working out or finding a suitable circuit that can be adapted
              Anyway hope this helps, I'll have a look around some more
              Cheers
              You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
              • Maxxarcade
                • Jul 2006
                • 973
                Great info, thanks!
                I'm going to start drawing up some basic diagrams this weekend, to get an idea of layout and operation. I think I'm going to have 8 different receivers, and 3 or 4 pairs of speakers to choose from. I'm going to need a big shelving unit
                • Brian C
                  • Dec 2006
                  • 156
                  Are u familiar with assembly language.... get a basic micro-controller like the atmel at89c2051, some tact switches, transistors and DPDT relays. Else u need some logic ICs like demultiplexer and switch debouncing circuit.
                  • shadow
                    • Feb 2007
                    • 732
                    A cheapo micro-controller will also do the trick and it would be done more easily than an electronic circuit. Although most micro-controllers (at least I think) can be programmed in C as well as assembly (some even support C++). It would not be a very big program, so even an assembly program won't be very big and won't take very long to write.
                    • starfury1
                      • May 2006
                      • 1256
                      And yours too shadow
                      I actually thought something like that would probably be a better idea but I know stuff all on them. (last time I played with asm was on a Z80 cpu years ago)
                      but for someone who knows there stuff it shouldn't be that hard I imagine
                      I was thinking along the lines of a single I/P selector switch, momentary push on
                      so you just step through the I/P relays (like a counter with 1 of 8 decode)
                      A "common" relay common to both sides
                      Then 8 relays each individually selectable for the output side
                      A "sense circuit" to detect if more then 2 relays are on
                      if you try and switch on a third one it kicks out the common relay.
                      So you have to switch one output relay off before switching on another.
                      (the idea is to save the amps from seeing to low a load)
                      (yes switch debounce is important too)
                      Anyway thats a very rough "form" of an idea.
                      cheers
                      • starfury1
                        • May 2006
                        • 1256
                        ok another few links
                        relay driver pdf basics
                        relay driver tutorial
                        A touch activated relay driver for automotive use
                        relay driver
                        another thought (and yeah why did it cross my mind before) you can get driver board for pc's
                        like the following here
                        But I an think you probably got a stack of relays just itching to put to work
                        So you want to do it without it costing you a Kings ransom of $$$
                        I guess the crude simplest way to go is toggle switches and relays and a psu
                        (but it does have a risk factor)
                        (or multi gang type switches as you said a headache)
                        anyway the above as ref material for you really
                        hope its of some help
                        andrew77 thanks for the link to that little proggie ..interesting
                        Cheers
                        • Maxxarcade
                          • Jul 2006
                          • 973
                          I've got the part down on how to interface the relays with the control logic, I just don't know how to make the front end control.
                          Seems that since only one of the eight input relays can be on at once, it would be an 8 input XOR circuit, with 8 outputs.
                          The confusing stuff comes with the output side, that needs to allow for any two outputs to be on at once. I think I'll just use manual control for the outputs and forget the control logic.
                          Each input and output would have one DPST relay, which would mean one set of contacts for each left and right channel.
                          So basically forget all the complex stuff... I just need a circuit that would allow me to push a button to turn on a relay, and if a different button is pressed, would cancel the first. I'll control the output relays manually with a simple latching circuit (press on/press off).
                          • starfury1
                            • May 2006
                            • 1256
                            humm well yeah simple is the best way to go.
                            I haven't thought in terms of digital gate logic in a long time so rather rusty on it all
                            which is why I didn't start suggesting the content of how you might do it, just a form.
                            but if I dream up something I'll post it
                            keep us posted on how you going with it Maxxarcade if you dont mind thanks
                            Cheers
                            • shadow
                              • Feb 2007
                              • 732
                              Hmm...I have thought about this for a little while and I like the idea of using Flip-Flops (such great useful things they are) however I have not figured out a good way for the 'reset' logic. That is, when one switch is pressed, all the others are turned off no matter what. This sounds like such an easy task, yet it has that one hairy part that is not so easy to get rid of.
                              That is why I have suggested using a micro-controller. It will probably end up being cheaper than making an electronic circuit and it can be 'upgraded' and further functionality can be implemented. Micro-controllers are fun things to play around with!
                              If worse comes to worse, I can write a small program in VHDL that solves the problem and I can use a 'compiler' (so to speak) and it can give me a electronic circuit for the solution of the problem.
                              • starfury1
                                • May 2006
                                • 1256
                                mx is going the simple route
                                but now his got me thinking about it and so with reference to my rough idea this would be the input side.
                                the 4017 IC is the puppy I was trying to think of well that type of logic anyway
                                Ic families have moved on quite a bit since my days with CMOS and TTL
                                see this page here
                                the bit of text is under the 2nd schematic with the 4017 and relays
                                you would have to adapted it to work with a momentary push on switch, if memory serves a flip flop would provide de-bounce for it.
                                this would allow you to step through (which is a down side I suppose) each input relay.
                                The up side is only one (hopefully) will ever be on..so you don't have to receivers (amps) connected to each other.
                                Note the use of Leds too.
                                The output stage as you said shadow could be done with flip flops (and relay driver interface) and the (above type) switches.
                                (I did find a circuit that used a 556 timer and an M P type switch here )
                                The "safety stage" (which is not really necessary but might save the amps)
                                Conceptually would be to monitor the outputs of the
                                output switching flip flops (or possibly ic relay specific chips)
                                and have in between common to all "safety relay" which disconnects the inputs and outputs from each other
                                This would trigger when 3 logic highs appear
                                sure it would be connected for a finite time but that worse case would be in Milliseconds
                                (yeah I know, transistors can die in micro seconds)
                                The idea of the protection is to stop the amps inadvertently driving too low an impedance by having more then 2 sets of speakers paralleled.
                                As I said you don't really need it.
                                (to me its a good idea for (hopefully) protection from the DOH! factor)
                                Anyway I'll just go with the flow as you got some of these way rusty old cogs turning
                                Yep small uP's have taken over and as I said above probably easier if you know how.
                                anyway
                                Cheers
                                • starfury1
                                  • May 2006
                                  • 1256
                                  A heavy duty one that could handle current for the relay coil (4way 6 way whatever) "rotary selector type" switch I guess would do this...you would probably want BREAK BEFORE MAKE contacts.
                                  something like this here
                                  or maybe you got a junked push button one of some kind
                                  going the digital path I think you will still have a little complexity...but maybe there is an easier way.
                                  the above is the simplest Ive thought of so far...but theres are always more then on way to skin a cat
                                  i'll see what else I can find or dream up.
                                  Cheers
                                  • Maxxarcade
                                    • Jul 2006
                                    • 973
                                    This diagram I posted earlier seems to be exactly what I need, I'll have to test it on a breadboard.
                                    • starfury1
                                      • May 2006
                                      • 1256
                                      Sorry Maxxarcade this was your original question
                                      (before I went off on spiel)
                                      If it switches a bunch of relays on and off then yes it would do what you want.
                                      I think as was posted the relay and trannie are more a representation of what should be there
                                      LS is an old family
                                      It won't have any DOH! factor protection but thats up to you anyway
                                      I take it you were going to have some RLY's as I/P others as O/P
                                      I'll have to have a better look at the finer details later got to run...
                                      BTW the safety thing above I did scratch it got a better idea.
                                      chers mate and yep do a bread board and see if it does the functions you need then go the whole hog.
                                      • shadow
                                        • Feb 2007
                                        • 732
                                        My mind finally clicked for a proper method of latching the value of a button and preventing two buttons being pressed at the same time. It is relatively simple solution (and it took me long enough to work it out dammit) but the number of connections increases a fair amount with every extra switch that is added to the circuit. There is probably a better way to solve the problem but it is a start. Now how to draw this circuit neatly with 8 switches. Hmmm
                                        • harp
                                          4001 sr latch / latch problem
                                          by harp
                                          I have simple circuit with cd4001, first is sr latch, which set is inputing from comparator, and reset is inputing from clock. Sr latch output is connected to hard latch I guess, but I do something wrong here... led 2 is flashing just as inverting clock... I want to led2 stay permanently on ance it lock signal, not to be interferencing with invalid state of sr latch. What I doing wrong?...
                                          Today, 09:43 AM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
