Damaged trace with continuity?
  • slidr
    • May 2015
    • 8
    I apologize if this is in the wrong forum, but this is a board from a car so it didn't seem like it belonged anywhere else...
    This is a DDM (Driver Door Module) from my gf's 2002 GMC Envoy, i.e. the board under the driver's arm rest panel that controls the windows, locks, heated seats, etc.
    These are notorious for being highly susceptible to damage from moisture, so much so, that they issued a recall (just not for this model year). http://www.thecarconnection.com/news...-for-fire-risk
    Nothing works on the panel, including the driver's door lock when the remote keyless entry is used (no audible clicks or anything). I swapped the passenger side door module and verified that it does work on the driver's side, so I'm pretty sure that the wires connecting to the board are fine.
    Here are some pictures of the only damage I could find on the board.
    http://imgur.com/a/3QW1p
    I don't have an EMR reader to test the capacitors, but they look ok. I cannot locate a wiring diagram for the car or a diagram for the board, so I'm kind of in the dark.
    Any ideas?
    1. Is the most likely cause of the failure moisture causing a short between the trace and the area occupied by the two vias, where the other damage appears to be?
    2. Can the trace still be damaged even though it's only showing 3 ohms of resistance, like most elsewhere on the board?
    3. Also, where the damage appears to be, what is the point of the two burried vias being there if they appear to be within the same circuit?
    Thank you for your help!
  • mmartell
    • Oct 2013
    • 3189
    Re: Damaged trace with continuity?
    I had one of these from a Chrysler minivan which I could not repair and found a replacement. Mine DID have some broken traces which allowed some led's to function again but nothing beyond that. Did you use a magnifier to check the board or just your eyes ?
    Btw, pictures should be posted to the forum using the "Manage Attachments" button.
    • mmartell
      • Oct 2013
      • 3189
      What about pins 16 and 15 are they ok ? And 3ohms seems a little high for a trace. What does your dmm read when the probes are touched together ?
        • 31278
        top right area on the first pic looks like a lot needs re-soldering.
        • slidr
          • May 2015
          • 8
          Ha, the same.
          And the pins are OK as well.
          • slidr
            • May 2015
            • 8
            Just my eyes. I have a loupe I can use to investigate more. Thanks for the recommendation regarding the pictures.
            • slidr
              • May 2015
              • 8
              Originally posted by slidr
              Ha, the same.
              EDIT: To clarify, I verified continuity/resistance from those numbered pins to the corresponding pins that would allow me to check that the traces are OK, and they seem to be OK. I also made sure that both ribbons were OK by checking for continuity/resistance at the pins on both sides of the ribbons and they all check out alright.
              • slidr
                • May 2015
                • 8
                To clarify my previous response (sorry, I had just taken an Ambien to get to bed), when the probes are touched together, I get 3 Ohms, and get the same when I check any of the traces on the board.
                Am I assuming correctly, that the typical resistance of a trace this size on your average board is wayyyyy less than 1 Ohm (wikipedia states that 1 meter of copper wire with 1mm of diameter has 0.02 Ohms of resistance)?
                Since my multimeter is unable to measure Ohms at this minuscule level, given the small sizes of most of the components on a circuit board such as this, could a trace be "damaged", but show up as otherwise healthy on my crappy DMM?
                Hypothetically, if a healthy trace has 0.02 Ohms of resistance, and this damaged trace has 0.20 Ohms of resistance, would that be enough to "break" the circuit?
                I realize the difference is small (0.18) Ohms, but looking at it in another way, that's an increase of 900%!
                • mmartell
                  • Oct 2013
                  • 3189
                  Hypothetically i don't know, I'd doubt it but I suppose it could depend on the circuit.
                  Sounds like your traces are ok and you have other problems. Try taking your meter outside and verify that the ic's are receiving voltage. Maybe there is a fuse on one of those boards ?
                    "wikipedia states that 1 meter of copper wire with 1mm of diameter has 0.02 Ohms of resistance)? Hypothetically, if a healthy trace has 0.02 Ohms of resistance, and this damaged trace has 0.20 Ohms of resistance, would that be enough to "break" the circuit?
                    I realize the difference is small (0.18) Ohms, but looking at it in another way, that's an increase of 900%!"
                    But you are dealing with copper trace that you need to know the trace width and the copper thickness to determine the trace resistance.
                    0.18 Ohms reading is not the problem, you have problem some where else.
                    • slidr
                      • May 2015
                      • 8
                      If I understand what you are saying, then the trace isn't the problem, but could be related to the problem, in the sense that a component directly connected to the trace could have been overloaded/damaged?
                        That's what it looks like to me, since I do not have the board or info about this board then I cannot tell you what that small trace is connected to. I have seen board that the traces were heated up and the green solder mask were blistered and expose the copper traces.
                        • Friend4Cap
                          Tuf gaming b550-pro damage circuit trace help!
                          by Friend4Cap
                          If anyone can help it will be very appreciate!!
                          Motherboard - (TUF GAMING B550-PRO) client connected Floppy Drive 4-Pin Power Connector to RGB_Header_1 +12V G . R . B and Burn one N6V8 and Damage all circuit trace, please check pictures, Motherboard not turning on & everything check ok, no short to ground, I need to repair all circuit trace and replace burn N6V8 but don't know where this 5 circuit trace connect to N6V8. If anyone with TUF GAMING B550-PRO can check. “Thank you in advance”...
                          05-07-2023, 05:38 PM
                        • re-atari
                          Gigabyte GA-H110-D3A schematic/boardview needed
                          by re-atari
                          Hello all,
                          Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                          This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                          02-24-2025, 06:45 PM
                        • abajor
                          A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                          by abajor
                          Like title says A2141 came in with Water Damage, customer desperately wants the data.
                          The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                          I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                          That said after cleaning up the...
                          12-21-2024, 07:16 PM
                        • chth96
                          Is it possible bridging tiny broken trace
                          by chth96
                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                          cutting tiny trace.
                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                          12-03-2022, 11:32 PM
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
