PEC? Semiconductor manufacturer identification
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    I've found this logo in many chinese diodes but never found a single datasheet or a website from PEC. Well, that's how I read that logo. Perhaps that's my fault. I've drawn the logo myself, with the hope that Google images would match something, but no results... any idea?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: PEC? Semiconductor manufacturer identification
    peccor.
    iirc they were just a rebadger of surplus.
    could be anything.the ultrafire of semiconductors.
    • KARTEK-PRO
      CuriousCure
      • Jun 2015
      • 3
      • India
      pec => PANjit International
      http://www.panjit.com.tw/
      proof: see pics in attached product catalogue
      • Teban1306
        [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
        by Teban1306
        Hello everyone!
        I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
        System Information:
        • Model: Lenovo ThinkPad T14 Gen 1
        • Machine Type: 20S1S4E600 (Intel i7 variant)
        • Current BIOS: N2XET42W (1.33) - Latest version
        • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
        What I'm trying to achieve:
        Replace the default "LENOVO" boot logo with a custom image during POST.
        🔧 What I've tried:
        09-14-2025, 11:49 AM
      • Alucio1970
        Help identifying PCB FS-750-2025 with TEA2025 – unbranded multimedia speakers
        by Alucio1970
        I'm trying to identify the origin of a circuit board inside a pair of unbranded stereo active speakers. No logo, no model number—just generic "MULTIMEDIA SPEAKER SYSTEM" printed on the front.
        Main details:
        • PCB marked FS-750-2025 with a logo that looks like a stylized sail inside concentric circles
        • Audio chip: UTC TEA2025, stereo configuration
        • Potentiometers: B50K (Volume, Tone, Power)
        • Capacitors: 470µF 25V and 1000µF 25V
        • Transformer: 230V~ → 19V AC 350mA, thermal fuse rated 115°C
        • Speaker: 5W driver with magnet labeled “JY ม5w” (Thai
        10-15-2025, 02:46 AM
      • conghuyms
        MacBook Air A2179 stuck logo , pls help me !
        by conghuyms
        Hey everyone,
        I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
        When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
        I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
        11-05-2025, 08:30 AM
      • martonmiklos
        HC0303-1B
        by martonmiklos
        Hi folks!
        I am trying to repair a Daikin air conditioning unit's filter board where I came across this ceramic coated IC:
        It is likely an AC-DC power supply converter, however there is no output voltage on it and I do not know if there are any enable lines for that.
        The primary side is clearly understandable: it has AC input and has a DC rail where a 100V 470 uF is present, however on the secondary side there are 4 pins and their function is unknown.
        I have not found any datasheets or schematics containing it on the web, so any guidance would...
        04-06-2024, 11:47 AM
      • grimacelord
        Component Identification
        by grimacelord
        Hello. I am working on a circuit board that is part of a motorized HDTV lift. The circuit board belongs to the controller component that tells the motor to either raise or lower the HDTV height.
        The controller started sparking when the 29V power supply was attached and the green light on the power supply would go out as soon as it was plugged into the controller board. This indicated a shorted component and I was able to identify which component it is that is causing the short. When I remove this component, the short is cleared.
        The problem is finding a replacement component....
        06-10-2025, 02:00 PM
