MOSFET question
  • nydirac
    • Apr 2015
    • 5
    • Italy
    MOSFET question
    Hi all! I recently began troubleshooting a TV (SHARP LC-32GD8E) and i think i found the cause of the trouble, there is a MOSFET (SSM6J51TU) that i think is not working but having very little knowledge about mosfet i thought to ask: the configuration is in the attached image (from the service manual of the TV) and the pins 1-2-5-6 are shorted (reading 0v), the pin 3 read 0v and the pin 4 read 5V... why using this configuration? what is the reason? protection of the 5v bus? I'm right in my assumption of a bad MOSFET? (no output in pin 1-2-5-6)
    PS: Sorry for the horrible articulation of the question... and maybe bad english?
    • 31288
    Re: MOSFET question
    check if q1703 is shorted.
    q1703 is acting as an invertor, it grounds the gate pin to turn off the fet that i assume is getting gate drive through r1728
    i cant tell more without more of the schematic.
    • Longbow
      • Jun 2011
      • 623
      Re: MOSFET question
      If you will look at the device data sheet, you will see that 1-2-5-6 are all internally connected. First things first, right?
      The voltages you give do not indicate a short in the device. Turn the power off and test it with your ohmmeter. Pins 4 to 6 shorted (i.e. 0 ohms)?
      Time to review: MOSFET basic operation. No conduction from Source to Drain until the Gate threshold voltage is reached.
      Is it plugged in?
        Re: MOSFET question
        It is simple electronics switch. The MOSFET is P-CH being used as a switch for sourcing the Voltage, so for the MOSFET to be turned on and supply the 5V out put on the Drain pin 1,2,5, and 6. the Gate (pin 3) Voltage must be 1.5~1.8V lower than the Source pin 4 (input).
        As shown in the circuit the Transistor has to be Bias on to turn on the MOSFET, if transistor is shorted out then you will have 5V on D pins.
        You need to find out if the Base of the transistor is getting the command on signal or not.
        You can manually turn on the MOSFET by connect 100 Ohms resistor between Gate pin 3 and Ground then you will see the 5V on the Drain output pin 1, 2, 5, 6.
        You should post this in TV section with all the info you have including the service manual and what the TV is not doing.
        • nydirac
          • Apr 2015
          • 5
          • Italy
          Re: MOSFET question
          Thanks to all for the replies! the NPN seem ok, and the pin 4-6 of the mosfet aren't shorted. Sorry for the unclear question! I simply don't understand why using a mosfet in this case (without bothering to put up the entire schematic... i'm stupid )...
          To semplify: I measured the voltages of all the pins and i have 0v on the gate and 5v on the source... so i have a gate-source voltage > 1,5V... why i don't have 5v on the drain? bad mosfet?
          I will create a thread on the TV section when i can't diagnose anything else, just started yesterday and i'm learning new and interesting things! I don't want to bother you guys with huge schematics while i can!
          Sorry for the ramblings!
            Re: MOSFET question
            If the Gate is 0V then it should be on, that will indicate bad MOSFET if you do not have 5V at the Drain pins, but you should check the resistance between the Drain pin and Ground to see if it shows low resistance.
            • nydirac
              • Apr 2015
              • 5
              • Italy
              Re: MOSFET question
              Thank you! Already done and the resistance seem compatible while on-circuit (around 2,8kOhm). I wanted a confirmation before starting to unsolder (and search) a 2,5x2mm ic...
                Re: MOSFET question
                May be you can may be 1A fuse or less between the S and D pin and see if the other circuits will function, that way if there is shorted circuit down the line you will blow the fuse instead of blowing the new MOSFET.
                You do see the G pin Voltage toggle HIGH and LOW, right?
                • Nooy
                  VGA MOSfet permanently shorted and loss of MOSfet pad
                  by Nooy
                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                  02-14-2024, 02:26 AM
                • chestercc
                  Alienware M18x Shorted CPU Mosfet
                  by chestercc
                  I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                  I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                  Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                  07-16-2022, 06:05 AM
                • mat2k
                  iMac 2017 PSU - shorted PFC mosfet
                  by mat2k
                  I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                  There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                  03-13-2025, 11:31 AM
                • daemon123
                  MSI GTX-980ti shorted MOSFET on memory rail
                  by daemon123
                  Hi All,
                  I have this MSI GTX-980ti Gaming Golden Edition. It had shorted mosfet on memory. Replaced the shorted i.e. Q47 PK616BA with 4C09N and the card ran fine for a month. Then suddenly again the same problem. This time when i replace it 4C09N or with replacement PK616BA (Aliexpress) it gets shorted. As soon as turn on the PC the PSU shuts down and the same mosfet Q47 gets short.
                  What should be the next step. Kindly guide.
                  The board view files for this gpu is available and attached. https://www.badcaps.net/forum/showthread.php?p=1237952...
                  05-10-2023, 11:05 AM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
