How to Calculate Fuse Value ?
  • mmartell
    • Oct 2013
    • 3189
    Wasn't sure where to put this...
    I have battery charger for a small lead-acid battery that is rated at 12v/1.0a for which a mosfet blew up and destroyed the small diode-looking fuse. I've made the necessary repairs but am at a loss for what value fuse to replace the old one with.
    Is it safe to put in a 1.25a fuse (a little more than the rated amperage output) or is it more complex than that ?
  • paulstef
    • Dec 2013
    • 724
    Re: How to Calculate Fuse Value ?
    If it's rated 1A it should probably limit the charging current to 1A. So it seems that a 1.25A could be suitable.
    If it was me I would probably monitor the current on an empty battery and then decide the fuse value.
    Why did the MOSFET blow up? Is there maybe more to it? Does the current limiting not work maybe?
      It can be really complicated, just read these tech info.
      You can try 1.25A for now since you do not have all the data such as as the surge current, the length of the surge, etc.
      • mmartell
        • Oct 2013
        • 3189
        Nah what happened was the output cable became frayed at the strain relief (thanks for nothing, strain relief!) so I took it apart to fix that. My guess is during the time I man-handled it I moved the heatsink for said mosfet enough that I made trouble with the shitty solder joints under it and when I powered it on, poof! It's repaired now and appears well under no load with a small piece of wire used as a temp fuse. Want to put a proper fuse in before hooking to battery for a load test.
        • mmartell
          • Oct 2013
          • 3189
          I did read a little b4 posting and so suspected it could get complicated. Thanks for the links.
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
