Looking for yet another tacticle SMD switch
  • Behemot
    • 4845
    • CZ
    After previous sucessfull search (the MP3 is back in operation…well, after resoldering the switch 3 times it almost does not hold in there while being pushed hard), I am looking for another SMD switch, this time for Point of View tablet. Check images for reference.
    The problem is, it measures aprox. 11 (12 with the metal plate) x 2.3 x 3.7 mm (W x D x H) and is right-angled. I have not seen anything like that, there are tons of 6mm switches everywhere.
    I may be able to use switch which has contacts aprox. 4 mm far, but those through-hole plastic pins (which help to hold in in place) are aprox. 2.5 mm far. Any idea?
    • 31151
    Re: Looking for yet another tacticle SMD switch
    it looks like it can take a throughhole version - how about a topdown foto?
    • Behemot
      • 4845
      • CZ
      Through hole? How? That won't hold for long.
        Why not? Through hole has greater mechanical strength than surface mount.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Indeed, A through hole will actually be stronger.
          Though... You are saying it is not strong enough.... Now unless the pads are lifting then it is the soldering joint that is failing... This is a fault with your soldering not the switch
          • Behemot
            • 4845
            • CZ
            It has only two contacts, I doubt it will be better than four solder tabs. Besides, it may tear off a layer of the PCB itself.
            Anyway, owner took the tablet away that it's not worth looking for the switch so I don't need it anymore…but if someone runs into these switches, post it here, may be good for next time.
            newtothis: yeah I soldered it better the third time, hopefully. But it is design flaw anyway, that particular switch in that MP3 gets toren off way too often. IIRC, this MP3 has been RMA'd with this problem two times while still under warranty and than I got it some time later with bad navigation switch, too. It'S in stupid place right next to a connector so you cannot even solder in there properly.
            • newtothis
              • Mar 2013
              • 1556
              • england
              Take it the tracks didn't flow through to the underside of the board then?
              I take it you were using an iron to solder them?
                • 31151
                there arent 2 through-holes in that photo, there are 4.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  There are 2 plus one from a track.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Had a bit of time to kill, but it didn't take more than a minute or two to find this:
                    https://cdn.badcaps-static.com/pdfs/...e0f642db9f.pdf
                    http://www.mouser.com/ProductDetail/...52boN6ltMN0%3d
                    If possible, I would probably put some sort of thing behind the switch (glue it on) to give it more strength.
                    Muh-soggy-knee
                      • 31151
                      think so?
                        • 31151
                        a bit like this:
                        http://www.rapidonline.com/electroni...e-switch-77306
                        • Behemot
                          • 4845
                          • CZ
                          …through-hole plastic pins (which help to hold it in place)
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            All three posts above ^^^ have me very confused
                            Muh-soggy-knee
                            • Behemot
                              • 4845
                              • CZ
                              I have no idea what stj is trying to say either.
                              Anyway, those switches you found are too small, the original ones are 11-12 mm, yours are only 6,9 mm. I already stated there are shitloads of 6mm switches, but I have found nothing as wide as 12 mm.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Darn! I could've sworn they were the right size .. oh well xD
                                Muh-soggy-knee
                                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 05:30 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • grimacelord
                                  NEC TurboExpress On/Off Power Switch Replacement Help
                                  by grimacelord
                                  I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                  I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                  I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                  11-09-2023, 09:49 AM
                                • SluggerB
                                  Help making a switch work the opposite way with a relay
                                  by SluggerB
                                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                  02-07-2025, 07:57 PM
                                  Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                  by sam_sam_sam
                                  Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                  ( needs more cam circuits for the machine to work correctly again )
                                  https://www.ebay.com/itm/275321870186
                                  To
                                  3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                  ( not 4 positions but the right amount of cams circuits )
                                  https://www.ebay.com/itm/274660439950
                                  I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                  03-18-2023, 05:12 PM
