HDMI Backfeeding
  • reaper57
    • Sep 2014
    • 216
    • Norway
    HDMI Backfeeding
    So guys my xbox 360 has been giving me some power issues lately and weird thing that I've noticed is that if I leave the HDMI cable plugged into the console and in my monitor my power supply's standby LED would turn on. It's not as bright as when it's plugged into the wall but it's pretty visible. This is with the power supply disconnected from the wall, but plugged into the console.
    Do you think that this is normal, and could it cause my console to shutdown and display a power error?
    Keyboard not detected, press F1 to continue...
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Re: HDMI Backfeeding
    Btw, here in Norway they use the two-phase system, and most power sockets are ungrounded. So basically pretty much everything that has a metal chassis has a constant current running over all the exposed metal parts. Escalators even zap you sometimes.
    • diif
      • Feb 2014
      • 6978
      • England
      Have you checked the voltages coming out of the adapter ?
      It sounds like some sort of grounding issue with voltage passing down the HDMI cable.
      • japlytic
        • Oct 2005
        • 2086
        Ungrounded equipment can induce noise through the cables and therefore cause problems - I've read about a seminar that someone held where everyone in the room was asked to remove their footwear due to the computers crashing due to poor grounding.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Okay, they REALLY need to adopt 3-phase power, like here in the US.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
            HDMI by design has a 5V, 50mA supply to power EDID EEPROM. This allows the Xbox to know what monitor it is connected to. A proper design of the monitor would use an OR-ing diode to power the EDID from either the HDMI or the monitor's PSU, but never allow the HDMI source to supply the monitor; it's possible this diode is shorted, but more likely the manufacturers cheaped out on the design.
            And, umm, Europe uses 3-ph everywhere. Most of the US is single phase supply from split-leg transformer with two hots. (You only get 230V when you combine your two phase-split hot circuits.) Most houses in the UK and EU only get 1-phase supply, but the supply system is 3-ph, houses are just tied off successive phases to balance loads as equally as possible. IIRC, 3-ph is only used for distribution and industry in the US - very few houses have it...
            • aliougm
              Marantz SR4003 AVR HDMI board issue, seeking for help
              by aliougm
              I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
              Connection as below:
              Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
              If I bypassed AVR then HDTV screen color be good.
              I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
              3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
              I replaced all...
              04-30-2022, 12:21 PM
            • japlytic
              Certain DisplayPort-HDMI cables can disable HDMI CEC communication
              by japlytic
              With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
              An examination of the HDMI CEC wiring...
              07-10-2022, 09:48 PM
            • spleenharvester
              Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
              by spleenharvester
              I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
              I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
              03-12-2025, 03:42 PM
            • RossMoodley1967
              LG LCD TV HDMI PORT FAULTY
              by RossMoodley1967
              LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
              02-28-2024, 08:38 AM
            • Wittie
              Philips 55OLED803/12 HDMI ports "half" defective
              by Wittie
              Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
              03-19-2025, 09:38 AM
