SMD Fuse Identification
  • Darky8
    • Jul 2013
    • 40
    Ugh, tiny little surface mounted fuse things... anyone got ideas on the values of these...? they have SD(?O)C 5000, and 3150 marked on them but marked as Resistors on the PCB.
    0.5 Amp and 0.315 Amp perhaps?
    Need to order some
    Thanks!
  • jetadm123
    • 2169
    Re: SMD Fuse Identification
    Since they are marked R101 and R12? on the circuit board, that would indicate they are resistors. 5000=500 ohms and 3150=315 ohms.
      I would say 5A and 3.15A, look through the catalog and see, or contact SOC.
      • Darky8
        • Jul 2013
        • 40
        There may be marked as resistors (for some reason) but they are open. Working ones elsewhere on the board not show any resistance either, so I'm pretty sure that's a red herring.
        Budm, I looked everywhere on the net to find them Thank you!
        Wow 5 amp, that's a fair bit. Hope it doesn't blow the things again.
        Cheers
          5A is my guess, that is why you should check the current draw with your DCA meter, for the fuse to blow it may be due to shorted circuit some where. You can check the resistance between each end of the fuse against GND to see what they show up as first before checking the current draw or before replacing the fuse..
          • Darky8
            • Jul 2013
            • 40
            Well I checked everything out and it seemed to be fine. I replaced the fuses but now all I can hear is the power supply flicking off and on The sound is from the Primary side and it's flicking off every second or so.
            PSU is fine without the DC/DC converter board, but as soon as it's connected it starts. It sounds like some sort of protection kicking in.
            It wasn't doing this before the fuses were replaced.
            Any pointers? I have included pics of the board and PSU.
            BTW it's a Panasonic WJ-HD316 Digital Recorder.
            • Darky8
              • Jul 2013
              • 40
              UPDATE : I took the fuses back off and the problem went away. I replaced only one of them and it was ok.
              So not enough to make the machine work, but it's the left hand bank of three looking at the top of the DC/DC board that is the problem.
              I can#t find anything obvious, any likely suspects..? Or could I bypass something to get the thing running?
              Cheers
                You do have problem some where in those switching power supplies (BUCK CONVERTERS) or the loads. You need to use Ohm meter to check the resistance of all the diodes, the SCR, the caps, the buck converter ICs (MD1222N) to see if any of them show low resistance in both directions.
                • Darky8
                  • Jul 2013
                  • 40
                  Budm, Thank you for your helpful images.
                  Everything checks out the same, except the SCR's (NEC 3P4J) with the non-functioning channel exhibiting less resistance (Anode to Cathode), but they both behave in the same way when polarity is reversed.
                  • Maniackk
                    Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                    by Maniackk
                    Device: PocketBook InkPad 3
                    Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                    I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                    I would appreciate help identifying this component.
                    Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                    05-16-2025, 08:53 AM
                  • Kaos62
                    Help with Qnap TS-130 component identification marked U3
                    by Kaos62
                    I wonder if anyone can help a newbie, I have a Qnap TS-130 that is totally dead. The component marked U3 in the photo seems to be shorted but I am havin trouble identifying it.
                    Anyone able to help please?
                    10-22-2025, 02:50 PM
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • CraigR
                    Diode Identification marked "DK"
                    by CraigR
                    I am not sure if this is the right place to post this but I need help identifying a surface mount rectangle diode and all that is printed on it is "DK" it seems to be open so I can't read anything off it. It's in a HP laptop by the power switch. TIA for any help.
                    06-17-2024, 01:41 PM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
