Dimmer instead of variac?
  • zx81
    • Mar 2014
    • 118
    Is it possible to use a triac based dimmer box in place of a proper variac to use for trouble shooting electronics. Can a dimmer be used to supply variable AC power to devices ?
    The dimmers I have are rated up to 2kw and I use them to dim tungsten lights for video work.
    • 31137
    Re: Dimmer instead of variac?
    no.
    a variac is a high current variable resistor that reduces the voltage.
    triac based dimmers mess with the ac waveform to create a pwm based output - they can damage electronic equipment by stressing the primary capacitor(s)
    • zx81
      • Mar 2014
      • 118
      Thanks for that stj.
      I will search evilbay for a variac
        • 31137
        good luck on the postage - heavy bastards those things!
        you should check carboot sales & that type of thing.
        • zx81
          • Mar 2014
          • 118
          What kind of power rating should I be looking at for a variac. Would 8amps be enough ?
          • zx81
            • Mar 2014
            • 118
            Would this do the trick ?
            http://www.ebay.co.uk/itm/Carroll-Me...item3cf521f833
              • 31137
              how should i know, you never said what it was for!
              • zx81
                • Mar 2014
                • 118
                Fault finding mainly TV's LCD, Plasmas, SMPS etc.
                • zx81
                  • Mar 2014
                  • 118
                  Oh forgot to add most importantly blowing things up
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    15 amp if you're going to do that...
                    Follow the white rabbit.
                    • Dannyx
                      AC Fan motor speed control ideas
                      by Dannyx
                      Good day folks. What I'm trying to achieve may seem pretty simple and although I found lots of discussions on the topic, it's hard for me to settle on a definitive answer, so I thought I'd ask for more opinions.
                      I have a small inline duct fan which looks like this, which I want to slow down, the reason being overall noise. I have no idea what type of motor this is, because I can't exactly take it apart to inspect it without ruining it, but perhaps we can work it out by examining its behavior.
                      Two things I've tried: a variac and a cheap light dimmer (triac+diac inside...
                      06-17-2021, 10:44 AM
                    • прямо
                      TRIAC circuit
                      by прямо
                      Anyone is familiar with a TRIAC circuit?
                      I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
                      With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
                      Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
                      My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
                      04-27-2024, 02:12 AM
                    • cathoderay
                      Miele cat and dog hs05 vacuum power supply
                      by cathoderay
                      Bear with me as this is getting interesting.
                      Not a lot as the saying goes but it may help someone to decide on throwing it in the landfill or rescuing it.
                      Symptom no go.
                      WARNING THIS STUFF CAN BE FATAL IF WORKED ON LIVE. PLEASE DO NOT WORK ON THIS LIVE UNLESS YOU KNOW WHAT YOU ARE DOING
                      YOU NEED A GOOD VARIAC AND AN ISOLATING TRANSFORMER AND SKILLS. IF YOU DO NOT HAVE DONT TOUCH.
                      A LOT OF THIS CAN BE FAULT TRACED USING CONTINUITY METER ONLY.USE A 12V CAR BATTERY FOR THE MOTOR TEST WITH AN IN LINE FUSE. 10A.
                      I'LL RUN THROUGH THE CONTROL BOARD TEST...
                      05-05-2022, 04:11 PM
                    • harp
                      triac phase control 0-100%
                      by harp
                      Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
                      06-02-2024, 09:00 AM
                    • Nevillet
                      Triac alternatives
                      by Nevillet
                      Hi All,
                      I'm trying to repair a coffee machine where the triac that controls the 240VAC water pump has failed and is latched on.
                      The water pump is controlled either on or off.
                      The triac is a surface mount BTA204S-800E. (datasheet attached)
                      I have a selection of other non surface mount triacs and need advise on selecting a substitute.
                      The triacs include BTA16, BT131, BTA208, BTA12, BT138, BTA06
                      Any help would be great.
                      Many thanks.
                      02-17-2024, 11:30 AM
