Damaged trace trough hole re wiring.
  • Ovox
    • Mar 2015
    • U.s.a
    I had trouble de soldering the old dc powerjack and got too impatient and damaged the traces in the process. I believe I damaged the inner layers of those three traces and tried to sand the mortarboard like the video below shows but the laptop still didn't work. Would I need to also sand the bottom and connect it to the top with an eyelet? My main question I wanted to know is there a way to solder the dc powerjack unto the next following test points if so how would I find them?
    http://imgur.com/Iq45mkk
    http://youtu.be/cTnVg6Pmf-U*
  • chth96
    Is it possible bridging tiny broken trace
    by chth96
    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
    cutting tiny trace.
    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
    12-03-2022, 11:32 PM
  • silberdrache
    Burnt Hole under IC on MacBook Pro M1 Pro 14"
    by silberdrache
    I'm new to this Forum, so I hope it's the right place for this topic.
    Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
    I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
    The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
    I opened it up and there were only three drops of coffee...
    11-10-2025, 11:19 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • XxMicroSoldering
    ASUS Rog Strix G17-712LV Laptop Liquid damaged
    by XxMicroSoldering
    Hello Guys
    I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
    10-17-2024, 10:45 AM
  • Tomylee
    Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
    by Tomylee
    I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
    It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
    I'm looking for help with the following:
    The exact identification or part number of the T5 component
    05-28-2025, 12:42 PM
