Making a atx12v power supply to test for short
  • macattack600
    • Aug 2011
    • 97
    possible?
  • macattack600
    • Aug 2011
    • 97
    Re: Making a atx12v power supply to test for short
    Originally posted by macattack600
    possible?
    Actually I am wondering what I can run from the ground to positive end of something 12v
    I want to push 12v through a pair of transistors but I need something on the positive end that draws power to feel the board get hot in a location
    So, atx -12v rail to -transistor. atx-ground to ground on board.
    I think ? and ground wire to something heavy 12v this idea work? The board uses transistors to turn 16v into 12v, there is a short to ground on the board.
      • 31278
      so you want to blow the short or make it smoke?
      that's going to do more damage.
      anyway, most psu's wont let you do that, you need to use a bank of caps that you charge and then connect to the short.
      then you will blow *something* but probably not what is shorted.
      what you really need is a low-ohms meter, there used to be circuits to build an audio tone version using an lm3909 that will find shorts usually.
      • macattack600
        • Aug 2011
        • 97
        possible?
        I accomplished this I ran them to a strip of leds and turned the power supply on with tweezers
        Last edited by macattack600; 10-21-2014, 05:19 PM. Reason: all it did was get very hot at the GPU...so replace!
