possible?
Making a atx12v power supply to test for short
Tags: None
Re: Making a atx12v power supply to test for short
Actually I am wondering what I can run from the ground to positive end of something 12v
I want to push 12v through a pair of transistors but I need something on the positive end that draws power to feel the board get hot in a location
So, atx -12v rail to -transistor. atx-ground to ground on board.
I think ? and ground wire to something heavy 12v this idea work? The board uses transistors to turn 16v into 12v, there is a short to ground on the board. -
so you want to blow the short or make it smoke?
that's going to do more damage.
anyway, most psu's wont let you do that, you need to use a bank of caps that you charge and then connect to the short.
then you will blow *something* but probably not what is shorted.
what you really need is a low-ohms meter, there used to be circuits to build an audio tone version using an lm3909 that will find shorts usually.Last edited by stj; 10-21-2014, 02:41 PM.Comment
I accomplished this I ran them to a strip of leds and turned the power supply on with tweezersso you want to blow the short or make it smoke?
what you really need is a low-ohms meter, there used to be circuits to build an audio tone version using an lm3909 that will find shorts usually.Last edited by macattack600; 10-21-2014, 05:19 PM. Reason: all it did was get very hot at the GPU...so replace!Comment
Assuming...7 Photos -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
by BabbarI found a project in the electronics trash yesterday. A nice Argon SA1 audio amp with some electrical issue. Took it apart and saw that the 4A250V fuse was blown so started lifting components to find the short. Eventually got to two MOSFETs (model FTA14N50C) that are shorted and when i took them out the short was gone.
Now i didn't have any replacements of the same model of course but i found a couple with pretty similar spec i thought (K10A60D & K12A50D) and put them in. Also replaced the blown fuse with a 3.5A250V one. Checked another time for short circuit and plugged it in.... -
by madan1Good day.
I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar... - Loading...
