I have UNI-T UTP3315TFL (2025 model) and just want to measure some zenner diodes directly with it. Set it to 12v and 7mA and connect BZX85C9V1 to it... shown on display 8.91v at 7mA... that seem fine to me. But, I guess I have in box a larger zener, let set it up to 16v, same current. Relay inside clicking to bigger range over 15v. When I test the sameone zenner accross probe, it clicks back to lower range, but displayed about 0v. The zenner was samehow killed by switching winding on 7mA limit... It was a 1W zenner, and can take up much higher voltage and current, so what is hapened realy, am I invent new psu quality test, or do some fullish thing?
question/caution note to usage of linear psu
I am not get it... the switching between taps is done before rectifier, and not interference with setted current limmit. If it generate a high voltage spike by induction, there is much control electronic on the way before get to the output. I am a bit worry, because, if it connected to some circuit (that has to be repaired) and start to switching between taps for any reason, it can silently kill protection diodes in mosfets, ICs, makeing them shorted........................... I like to hear from different users and psu (linear) model, if they can perform above zener test and worrylessly swipe a full voltage range at fixed 5mA limit with no damage a diode, to dismmiss a possibiility to only one issue with my model/these model from UNI-T?Comment
I just kill another 9v1 zenner at 5mA, that say, it is repetable indeed. I have no digital scope so I can do only a yt review, capture execution on video clip... so guys be aware of that. I think it is only issue specificaly with zenner and zener properties to conduct at some point and too slow regulation (or too fast letting go) that control current. When it switch to lower tap, current limit is fast release in gap while induction surge hit zenner and slowly initiate again when is diode yet damaged........................ This topic is for someone who has needed equipment (on mind eevblog), I beleave that is no likely manifest in real circuit... but...
not happy at all...
When testing zener diodes use a resistor in series with the + output of the PSU, 1k or 2.2k, you can use lower resistor values if you want to test at a higher current
Haven't tried just relying on the current limit, as my bench PSU doesn't have that precision
Of course the zener diode will "break down" once you exceed its rated zener breakdown voltage
Maybe the current limit is too slow to react if you start at a higher voltage, you can test what happens if you do the opposite: start at lower voltage and slowly increase the voltage until you notice an increase in current and the voltage stabilizesComment
The initial idea was to use psu as measure device, not only as power source. The whole purpose of haveing a current limit is to prevent damaging circuit, and I use and explore that option... if the current realy stay at 5mA level all the time I dont think that while switching taps there can be enough surge power to damage 1w diode........................... So function of CC is no acomplish his task for fine electronic, I see that on that way...Comment
For these who want to test your linear psu, this is setup: set the voltage of psu al least to pass to one higher transformer tap (or simply to 30v) then the testing zener is, and set fixed current at 5mA. For these who have 3 digit display, you can anyway set fine current using a external dmm with caution. Example and procedure for 9v1 zener is: set voltage to 19v, current to 5mA, and connect zener across the probe (anode to ground), then read voltage on display, it will be about 9v, write on papers all digits and disconect probes. Again connect probes and read voltages on display - if the zener was damaged in this proces, the reading will no to be same, every time is lower and lower... In this example is using regular transformer for psu with taps on 8v, 15v, and 23v.Comment
if the tap changes on the fly then you will see a big increase or decrease in input voltage of the linear regulator section.
the regulator output will reflect that until the feedback makes it compensate for the change.
i guess the regulator feedback isnt fast enough to save the diode.
if it was my design the microcontroller wouldnt allow you to change tap while the output is enabled.
maybe it doesnt have a microcontroller and the tap relays are controlled by linear feedback.
that would be bad!Comment
I go with extend testing and kill some regular LED diode at "5mA". Now I can conclude, it is not issue about switching between taps and induction, but inertion of regulation circuit to do real "constant" current. I tested in first range on 7.6v (without switching occure), and noticed that led initialy briefly flash much stronger that can on 5mA. Then I set it to 10v, and visualy is the same even switching occure. LED stay undamaged. Then I setup to 30v, and led instant die after initial flash...................... as many as I watch lab psu review, in all is pay attention to not overshoot in voltage while switching taps, but never seen a measurement of overshoot in current... what is consider good, normal, poor I dont know...Comment
https://www.eevblog.com/forum/projec...-diode-tester/
Originally posted by enut11Hi @johnwa. Nice little project. I am an incurable electronic gadget man but for zener testing I use my power supply set to a constant current of a few mA. Starting at zero I wind up the volts until CC sets in and reveals the zener voltage.
enut11This looks like the correct answer, by the time your PSU switches from Constant Voltage to Constant Current, the zener (or the LED) dies by the initial voltage/current spike; what you need is a constant current supply with a high enough compliance voltage for the DUTOriginally posted by johnwa(For anyone else who wants to try this, make sure you follow enut11's advice exactly, and wind the voltage up slowly from zero - many power supplies have poor transient response and/or excessive output filter capacitance, which could otherwise result in damage to the DUT)
Most linear bench PSUs have a big output cap around 10000uF or moreComment
Have a good read through https://www.eevblog.com/forum/testge...ower-supplies/ and you will see why you keep blowing zeners.
Best practice is to use a resistor in series with a known voltage, and forget about the current limit on the PSU.
Or build a dedicated zener diode tester, like this one: https://www.siliconchip.com.au/Issue...r+Diode+Tester"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
"and forget about the current limit on the PSU."... and for me that is the only point of haveing lab psu in use........................... Have someone schematics of that psu UNI-T UTP3315TFL, I have noticed that they did a improvement in meantime by ommitting vr6 and vr8 in 2025 selling model... and flip over top to220 element... How hard can be that do a propper CC function, I dont think thay pay any attention at all for startup detail in firstplace... so perhaps it can be easely fix?Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes I read eevblog link, and see there is the same issue even with branded psu. Everything point to electrolitic capacitor on output, so that seems for that ammount of energy isnt controlled... ridiculus... for my perspective it is a mayor flaw in design, and wonder how and why that problem isnt yet consider by (analog) psu designer, even on cheaper one psu... Now I have to worry if my psu has silently destroy some components while "repairing" something.................................. Everything starts with try to test zenner, but now it really isnt it, it is about psu, has he deliver what supposed to do all the time, partialy or just in some condition...Comment
They do talk about some high end supplies having no output capacitors and even extra transistors to pull down the ouput voltage faster when needed, but those are big $$$$ gear."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
by kuba2102Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...01-06-2025, 09:14 PM -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by прямоWas looking for a simple CV CC linear supply to build and came across this one.
https://oshwlab.com/svalentin544/lab...ply-0-38v-0-5a
I etched the provided board design and populated it.
The output voltage adjustment works.
The output current adjustment however, doesn't behave like I expected it to be. If PR2 is going clockwise, the output voltage decrease. Adjusting R5 has no effect.
I don't have a load connected to the output at all.
Can someone explain how the current adjustment work?... -
I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
by biluxHello everyone,
I want to find a replacement for uP0109 8pins, and i found this parts:
uP0109 is "2A Ultra Low Dropout Linear Regulator"
RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
FP6137C is "2A BUS TERMINATION REGULATOR"
can replace uP0109 by RT9199 or FP6137C ? - Loading...
