panasonic no picture
    hi I have a Panasonic TX-L42E3B uk model 240 volts the problem with it is the is sound but no picture the backlights are working and reacting to the picture going darker and lighter but the picture is not there I have changed the power board and t con board and ribbons but no change if I unplug one cable from the tcon board there is no change is there anyway to reset a Panasonic please be aware I can see nothing on screen no menu or anything would a new main board do it or do you think the panel itself is at fault thank you in advance
    Re: panasonic no picture
    did forget to say that all voltages from the power board are spot on
      Check the voltage on both sides of the tcon fuse - it's possible you got a bad one.
        checked and 12.1 on both sides
          MOST times the presence of audio implies the main board is functioning. Try reseating the LVDS cable on both ends and even the tcon->panel ribbons while you're at it.
            cheers I have reseated all cables I have replaced all cables I have replaced the tcon board,power board bit stumped the picture just went off with no warning
              I have now changed the power board,main board,t con,board and inverter board ,if I unplug one ribbon I have picture on one side if I swap the ribbons it is just the same half a picture and other side is white
                any help would be welcome cheers
                  you should have opened your thread here, https://www.badcaps.net/forum/forumdisplay.php?f=31
                  there are loads of tv gurus
                  best to open a new thread there or ask a moderator to move your thread there
                    if im not mistaken the problem is the screen.....are you being try to replace the screen..
