Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
  • Techie_hobby1
    • Feb 2023
    • 57
    • England
    Need some help please with a few components on this small board so that I can troubleshoot the circuit.
    The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
    J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
    J2 - to DC Output
    J3 is Battery cell connector
    however I am struggling to identify if:
    Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's. I am fairly sure they are NPN Transistors though because I get a 0.6v diode reading on Collector and Emitter with +ve on Base.
    Same for Y2 (SOT-23) being PNP with -ve on Base and 0.6v on Collector and Emitter.
    The 8 pin IC is a little odd though but with no markings is making it a lot harder.
    If I am incorrect with any of the above please can you advise further
    Many thanks
  • truclacicr
    • Apr 2019
    • 306
    • australia
    Y1 = SS8050.
    https://www.google.com/search?imgtyp...Cisz%3Am&udm=2
    Y2 = SS8550.
    To identify the IC, you would need to identify its pinout.
    https://ipv4.google.com/search?q=fil...8%20OR%20soic8
      • 31015
      the switch has fractured soldering
      • Techie_hobby1
        • Feb 2023
        • 57
        • England
        truclacicr
        Thanks as always. I think sometimes I over think it in regard to the component searching, and try to use the sites that let you search by the Marking code, instead of trying to do a standard google image search first.
        In regard to the IC 8pin SOIC connections are as follows ( I think it is just 555 timer chip - but just want some clarification please):
        Pins are as follows:
        Pin 1 connected to Cathode of D1 diode and bridged with pin 4
        Pin 4 goes to collector of PNP (Q3) transistor via current limiting resistor
        Pin 2 goes to collector of NPN (Q4)and also to collector of NPN (Q1)
        Pin 8 goes to Anode of the same D1 diode, to DC positive
        • Techie_hobby1
          • Feb 2023
          • 57
          • England
          stj
          Thank you for pointing that out. I actually didn't see that one. I think I managed to locate a few that were broken/cracked.. and still going through them slowly
          • Techie_hobby1
            • Feb 2023
            • 57
            • England
            truclacicr
            whoops I forgot to include pin 7 of the IC, which connects to the base of NPN Q5 transistor
            • Techie_hobby1
              • Feb 2023
              • 57
              • England
              truclacicr
              Now I am really baffled.. I have just realised it does not have any connection to pin 3 (Ouput) so can't be a 555 timer can it
                • 31015
                the chipis probably a 2cell lithium charger or a microcontroller.
                • Techie_hobby1
                  • Feb 2023
                  • 57
                  • England
                  stl truclacicr
                  Very quickly hand drawn a schematic - could have switched a few things around but think you get the jist
                    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                    by sam_sam_sam
                    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                    04-09-2023, 08:04 PM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
                  • rddube
                    Lenovo L490 Ram voltage circuit malfunction
                    by rddube
                    Hello friends,
                    Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                    I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                    07-15-2025, 04:41 PM
                  • Tarot Superstars
                    Short Circuit tester
                    by Tarot Superstars
                    Hello.
                    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                    Link
                    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                    https://www.youtube.com/watch?v=0eixDdCpiO4
                    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                    09-25-2023, 09:11 AM
                  • edugimeno
                    Stagg sms12p audio amp has water damage
                    by edugimeno
                    Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                    I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                    There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                    There is only one signal wire connecting the first boards...
                    05-24-2025, 06:00 AM
