Switching DC power supply 0-120V 0-3A power LED 3 digits display power Feedback wanted
    • Jul 2011
    • 6069
    I found this switching power supply when looking for some switching power supply
    https://www.ebay.com/itm/31523786004...Bk9SR4a_y-zuYw
    Has anyone ever used this switching power supply before if so what do you think of it quantity and durability
    • Jul 2011
    • 6069
    How safe would it be to use in troubleshooting switching power supplies
      • 31246
      i think a box full of switched lamp sockets to create a programable currentr limit would be better
      you DONT want to power a switching psu with a source that drops the voltage - some psu's will go into a reset loop and go boom - specially TOPswitch based ones.
      brownouts are bad to switching psu's
      you also cant reliably use DC to power anything with active PFC.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8339
        Mine is linear and it stays that way for bench top PSU
          • 31246
          nie if you can find a used one, torioid based psu's arent cheap - neither is shipping
            • Jul 2011
            • 6069
            This is the reason I ask the question that I ask about things that I plan on doing I want do things the safe way because safety is a priority concern
            Could you please post a website link for the type that you are talking about because I am not sure how to about finding the type that you are referring too
            What type of bench power supply that you use could you please provide a website link to type you are referring to
              • 31246
              start with something like this:
              https://www.aliexpress.com/item/32528574606.html
              so you can see current draw and any pfc fuckery going on.
              i have a box i built with one of those and a 16A breaker/ 30mA RCD in it and a pair of test sockets on the end - very handy on questionable stuff.
                • Jul 2011
                • 6069
                What about something like this
                Digital Display 0-120V Variable Linear Adjustable Lab DC Bench Power Supply
                https://www.ebay.com/itm/35571784549...Bk9SR6yFgejwYw
                I found this one on eBay
                Din Rail Multi-function LED Digital Energy Meter AC 80-300V 250-450V 0-100.0A Ammeter Voltmeter Volt Amp Voltage Current Meter
                  • 31246
                  it doesnt say the current
                  and it's not linear - it says "Switching Dc Power Supply"
                  not that it matters.
                  these look better
                  https://www.ebay.com/itm/355057379567
                  https://www.ebay.com/itm/355622243473
                    • Jul 2011
                    • 6069
                    not that it
                    I have decided that I am going to go ahead with the one that I asked about in post # 8
                    because it uses aTL4949 ic chip to control voltage and current in this switching power supply the one thing that I am not trill about is that it use a TYN277 ic chip
                    This where I saw what is in this switching power supply board
                    https://www.youtube.com/watch?v=ib1AcwGTF9Q
                    Here is one for the post number one of this switching power supply tear down it is for the 60 volt version but I would not be surprised if uses the same board but with a higher voltage switching power transformer
                      03-31-2024, 02:12 PM
                      07-01-2024, 06:34 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                      DVR camera recorder switching power supply capacitor failure really
                      These cheap non brand capacitors at it again
                      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                      Well at least I have the cameras back on line I to try the...
                      01-22-2022, 06:28 PM
