please help with complex dmm connector
  • harp
    • Jun 2022
    • 643
    • Planet Earth
    Maybe now he decide to post... This forum is become so unreliable... I hope you see the attachment... So, I have newer cheap 830 dmm, and I am not happy with beeping mode. Its output is from IC directly, so he wont beep unless the diggit become too low. I want to beep function is thrully analog, like the old one, and think to atempt modification with insert beeping circuit. But, I dont know principle of reading such complex connector, so please if you can draving with red lines path that exist in beep mode... it will help me a lot.
  • harp
    • Jun 2022
    • 643
    • Planet Earth
    This A830L ... https://www.eevblog.com/forum/testge...tery-function/
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      You'll also have to trace the new DMM more importantly unless you have the schematic for that too, so you'll have practice there too. However the lower right using the two op amps and the transistor is the beeper circuit (one op amp is the threshold, other op amp is oscillator for beeper, transistor for turning the beeper on) and everything else is just a connection to that circuit. The main select switch just connects the beeper in just in the beeper mode else apparently selects the 2KΩ mode. Whether this is applicable or not to the new DMM is the question.
      • harp
        • Jun 2022
        • 643
        • Planet Earth
        I have no schematic, but it looks like bare minimum... so what is another piece of voltage divider, is connecting v+ throug probes, and 100k to ground?
          • 31255
          try this
          • harp
            • Jun 2022
            • 643
            • Planet Earth
            Thank you, I am not able to ask any question more, dont know how to ask a question that help me future... I search for schematic who contain rotary drawing connector switch (like on yours) and continuity circuit (like on my sch) as well, but not find it... but found a interesting site with plentyfull dmm schematics... http://improwis.com/projects/reveng_multimeters/ Anyway, nothing without opening the dmm before any clue how to approach modification... whats can go wrong, right? (:
            • Tomylee
              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
              by Tomylee
              Sorry for the person who’s going to read all this !
              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
              07-11-2025, 11:52 AM
            • 5mall5nail5
              Help identifying connector for ASUS 4090 Strix RGB LED connector
              by 5mall5nail5
              Hi All -
              I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
              Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
              05-04-2025, 07:47 AM
            • bussincaps
              MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
              by bussincaps
              Hello All,
              tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
              Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
              eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
              Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
              I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
              08-03-2023, 12:57 PM
            • michhak
              Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
              by michhak
              Hi guys,
              i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
              It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
              11-17-2021, 05:45 AM
            • m1ch43lzm
              70mai Dash Cam A510 - help identifying connector on camera module
              by m1ch43lzm
              Hi everyone
              I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
              The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
              I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
              05-11-2025, 06:02 PM
