Just need some help to confirm what this mov is. So far all I can make out is N241K & JVR. I'm not familiar with these but hoping someone is.
Need help verifying this MOV
There would be a number (diameter) prior to the N241K IE: 10N241K (10mm)
The N series are High temperature series, D series are Standard series 10D241k which should work and are easier to find
Page 13 of the 10N-series pdf explains the difference between the series lettersLast edited by R_J; 06-04-2025, 05:57 PM.
by Rezidi've got an A2337 820-02016 that has no power. No sign of liquid damage and no obviously damaged components. The board looks brand new. USBc amp meter does not turn on when plugged into either port. I've tried multiple known good chargers and usbc boards. No shorts on any of the large coils. Not super familiar with diagnosing Macbook boards so any help is appreciated.
USBC1_CC1 = 1.6v but fluctuates to .9v
PPVBUS_USBC1 = 0v
PP3v3_UPC1_LDO = 0v
PPDCIN_AON_CHGR_R = 0v
PPVBAT_AON_CHGR_REG = 0.07v
PPBUS_AON = 0.07v
I'm thinking... -
by adelfr2009I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3Vā4V after the sense resistor. No component gets hot, except the CPU which becomes... -
by CDNBrewerHello Everyone,
I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
Symptoms:- Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
- Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
- I swapped the Left and Right surround
by H HHello,
I'm hoping someone could help me confirm if I have identified the following parts correctly.
Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
The parts needing replacement are on the back of the board behind the HDMI input.
I have identified the parts as the following:
C6037: MLCC 0.1uf/16v(0402)x7R W05
R6016: RES 499 OHM 1/16W (0402) 1%
LB10911: Ferrite Bead (0402)...5 Photos02-16-2025, 01:09 PM -
by HarleyFoolI have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
I have removed the back of the TV and looked...12-21-2021, 02:40 PM - Loading...
