Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
  • Tomylee
    • Oct 2024
    • 18
    I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
    It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
    I'm looking for help with the following:
    The exact identification or part number of the T5 component
    A possible replacement or equivalent part
    Understanding its function (protection diode? TVS? regulator? something else?)
    NEXIQ refuses to share technical details unless I send in the entire unit for repair, which I'd like to avoid for a simple part replacement.
    Thanks in advance to anyone who can help!
  • Tomylee
    • Oct 2024
    • 18
    • lotas
      • Jan 2016
      • 4589
      • Russia
      This is a choke, you can put two jumpers from thin wire and that's it.
      • Tomylee
        • Oct 2024
        • 18
        Thank you so much for your help! Your response was really helpful in understanding the component and moving forward with the repair. I truly appreciate the time you took to assist me, have a great day !
        • Tomylee
          • Oct 2024
          • 18
          By the way, Lotas, how did you know it was just a choke? Did you search for and find documents or anything to come to that conclusion, or did you just know? I’d really like to know, if possible, so I can learn how to solve similar problems in the future. Thanks
          • lotas
            • Jan 2016
            • 4589
            • Russia
            The USB input circuit is roughly the same on all devices...
            • ZoOLf
              Help identification component on water damaged MSI 1070 Gaming X GPU
              by ZoOLf
              Hi gents,
              so i recovered a liquide damaged GPU (MSI 1070 Gaaming X) i try to fix it,
              the corrosion is so bad that it ate some component's pads.
              some are easy identifiable, others are not, from a similaire Boardview (Msi 1080GTX attached) I got some info:
              1-in boardview the component is named SOT23-5 no other info:
              from the pic we can see marking L1C9.
              no datasheet available and I cant find where to purchase it, What other Ref can I use instead.
              2-not available in the boardview but i guess its Sot23 (marking 2A. and...
              07-24-2021, 03:52 AM
            • XxMicroSoldering
              ASUS Rog Strix G17-712LV Laptop Liquid damaged
              by XxMicroSoldering
              Hello Guys
              I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
              10-17-2024, 10:45 AM
            • Powderfanupnorf
              Dell AL440LX power on switch circuit help required
              by Powderfanupnorf
              Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
              So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
              My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
              06-24-2024, 01:24 PM
            • GTAVC16
              Alienware 18, Nvidia GTX 880m presumably shorted
              by GTAVC16
              Hi guys!
              I'm in need of some support so I can try to fix my laptop/gpu.
              While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
              I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
              No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
              I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
              However, I know...
              08-20-2023, 05:39 AM
            • Shulgin
              Acer predator XB241YU Component identification
              by Shulgin
              I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
              After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
              In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
              I...
              05-11-2024, 11:06 AM
