Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
    • Jul 2011
    • 6093
    • Soldering Junkie
    Originally posted by eccerr0r
    Yeah it is dangerous, was planning on building a dual LM317 CC/CV linear charger in the meantime (~70% efficient straight from panels) though technically... I should be able to use that linear supply and bypass the transformer/diodes and have the same efficiency... HMM...
    If done right it should work fine just make sure that you use a couple of heat sinks on the LM317 if you can find the T3 mount type it has better heat transfer than the 220 type just make sure that you the right wattage resistor because if you are going to use one amp output mode
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8795
      • Fixing Failed Fuhjyyus
      Think it would be better if I hacked the otherwise useless 24V linear PSU which uses 3 TO3 series pass transistors and a LM723. Just need to hack in a viable current limit and should be good to go. It'll be more efficient with the solar panels I'd think because it won't need to drop as many volts since the PSU transformer output is higher voltage... (The linear psu was already rated for 6A continuous so this will be better than any LM317 design I could hack up short of one that also has series pass transistors.)
      however will need to redesign the psu to run totally off the solar panels, currently it uses two windings on the transformer to allow for instant on/off.
      Still want to target a SMPS solution somehow. Need to get efficiency up so arbitrage is viable instead of trying to target just absorbing excess.
        • Jul 2011
        • 6093
        • Soldering Junkie
        There is an issue with the volt / current meter module the current meter is a little over one amp off in its reading results which I will probably remove it and use a different meter module after I run some more tests today if the sun will corporates will me long enough to determine if it can or cannot charge 12 volt battery packs on one solar panel
        Still want to target a SMPS solution somehow. Need to get efficiency up so arbitrage is viable instead of trying to target just absorbing excess]
        I would be very interested in what you come up with if you can get this to work
        Also how well dose a GTI work on 220 volt without using a neutral tap for 120 volt circuits
        I am having hard time understanding how you could get this to work correctly and not not have issues with this setup now a 220 volt device no issues doing this
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8795
          120V GTI works because there's an autotransformer somewhere and it could be outside your house. Same with 240V but I'd not get one for 240V w/o a ground tap. And definitely not a 220V one rated for 50Hz.
            • Jul 2011
            • 6093
            • Soldering Junkie
            Well did some testing on a 12 volt battery pack with the boost converter and results are what I expected it to be at 12 volts what ever the voltage is the battery pack voltage is very close to that and the same thing with the current is very close to the same between the solar panel and the battery pack voltage
            Which is what I expected now the current did come up to 6 amps until the battery voltage was at 13.5 volts and this also what I saw with the MPPT solar panel charging controller so this part looks good so there description seems to be accurate in that does function like a MPPT charging controller to some extent now when it is in the boost mode the current is almost half of what the solar panel current is which is what you expect being in the boost mode so the results are decent
            Now weather or not it can handle 100 amps input I with what has been mentioned above maybe it can but I have my doubts because they are using the enclosure as a heat sink and a cooling fan which actually does come on when the enclosure get to warm
            I just not sure if the enclosure can dissipate that much heat that 100 amps input from the solar panels I do not think that I will ever get that close to what they claim it can handle
            I have a concept about running one of my battery testing machines on a solar panel / battery pack setup I think it might be feasible to do it because it runs on 24 volts switching power supply and the functioning controller is running on 12 volts from a linear voltage regulator a LM7812 ic chip
            I am thinking that it should work because the buck converter only controls the current output from the buck converter which is a XL4015 ic chip so I think I can use a couple of these 24 volt battery packs from BH and it should work ( I going to give some more consideration think about what could go wrong with this concept)
            I am very interested in your project about doing a SMPS power supply for a solar panel charging system
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8747
              I think as higher the voltage difference is heat becomes a problem and thus limits you current output.
                • Jul 2011
                • 6093
                • Soldering Junkie
                #27
                I became aware of this because of the difference of input current versus the output current which would mean that the mosfets are switching harder which would increase the possibility of generating more heat
                Now if you keep the voltage difference to a minimum of what is needed then you get more current output and less chance of producing more heat than necessary now I could be wrong about this assumption if I am wrong please correct me if I am wrong about my assumptions
                More testing needs to be done to understand how much difference in current will produce an acceptable result and not be a danger of thermal runaway situation and destroy the entire circuit to point of no return
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8747
                  Nohing to correct here Sam… you are on the right path! The circuit shouldn’t be allowing thermal runaway to the point of no return. It should go into protection mode.
                    • Jul 2011
                    • 6093
                    • Soldering Junkie
                    #29
                    The place where I bought two 100 watt panels 12 volt at 6 amps for $49.00 each
                    Now they had a 190 watt panel for $109.00 12 volt at 9 amps but a floating voltage of 24 volts instead of 20 volt on the 100 watt panels ( one note these panels are 1/2 off the original price as well )
                    I going to see if I charge the 24 volt battery packs from BH
                    Because I was not happy with the results that I got from one single 100 watt panel trying to charge a 24 volt battery pack on it I was only getting about 1/2 of the current output I would like to see around 75 to 80% of the input current because at around 5 amps output I was getting around 3.5 I want to get it closer than that
                    The problem is if you put two 100 watt solar panels in parallel I will have a 40 volt floating voltage I can not use it this way because the input voltage needs to be a little lower than the battery voltage is
                    Ideally I would like to only see an amp difference between the incoming and outgoing current or closer if possible when not near the battery cutoff voltage point because the cutoff voltage for these battery packs are around 30 volts I do not want or need that much current when the battery pack is nearly fully charged a waste of energy from the solar panels I need more current when the battery cells are at a low state of charge this is where I need the most current available
                    If this works better than the 100 watt panels I will buy a second one so I can charge 4 battery packs at one time
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8795
                      #30
                      What's the total surface area of the 100W panel?
                      Again I once bought a panel that was supposedly 100W but only could muster 60W. Can it get 5 amps short circuited? The panel will never supply more than Isc so it's worth testing. A proper boost circuit should easily hit close to a short circuit as it charges the inductor up with the fully-on mosfet....
                        • Jul 2011
                        • 6093
                        • Soldering Junkie
                        #31
                        Here is the website link where I bought these 100 watt solar panels
                        https://hqsolarpower.com/hqst-100-wa...Q2OW7Wp9_HTDV7
                        Here is the website link where I bought a 190 watt solar panel
                        https://hqsolarpower.com/190-watt-12...e-solar-panel/
                        One note apparently this company also has a problem with responding to emails when customers have issues with one of their products something similar to the issue that you might have with Battery Hookup they both sell decent products but you are basically on your own if you have issues with any of there products this seems to the norm now with online ordering Iin general I do not understand how and why companies think that customers service is not very important anymore but this trend has become more prevalent over the years this is one more reason I am saying that corporate America is sick and needs to get there act together
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8795
                          #32
                          Hmm..I don't recall hqst giving bad panels, but did you try the open circuit and short circuit tests? I'd hope you'd get at least 80W from the 100W panels when not using mppt. But yeah efficiency apparently is the matter, and CS with their own bad panels is "just a small cost" that may not justify better CS or QC...
                          BTW looks like your 100W is a 30 cell, and likewise my 30-cell panels, a lot of hardware don't like them (and there are a lot of hardware that do...)
                            • Jul 2011
                            • 6093
                            • Soldering Junkie
                            #33
                            I did some testing with this 190 watt solar panel that I bought test results as follows
                            9.5 short circuit
                            24 volts no load
                            With the boost converter I get 9.1 amps and when the fan kicks on the amperage is around 8.8 amps
                            Charging a 24 volt battery pack the
                            input current at 9.0 amps
                            input voltage 24.5 volts
                            input current to battery pack 3.35 amps
                            input current 9.0 minus output current is 2.5 to 1 ratio but this with battery only having about 25% battery life left in it as the voltage goes up the output current will go up slightly but I am not sure if this is very efficient to use with battery voltage being low in the beginning not bad when the voltage gets closer to 25 volts it will be slightly higher in current
                            I will have to buy another 190 watt solar panel and hook it up in series and see if the results are any better or I will just use the MPPT solar controller
                            • Boardview and Schematic Bot
                              Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                              The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                              The bq24745 features dynamic power management...
                              10-23-2024, 02:50 AM
                              Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                              I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                              I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                              I tested the battery cells there are installed right now and they are testing good with no issues that I...
                              02-04-2025, 08:08 PM
                              AOZ2261NQI-11 Datasheet
                              General Description
                              The AOZ2261NQI-11 is a high-efficiency, easy-to-use DC/DC synchronous buck regulator that operates up to 28V. The device is capable of supplying 8A of continuous output current with an output voltage adjustable down to 0.6V ±1%.
                              A proprietary constant on-time PWM control with input feed-forward results in ultra-fast transient response while maintaining relatively constant switching frequency over the entire input voltage range. The on time can be externally programmed up to 2.6µs.
                              The device features multiple protection functions such...
                              10-07-2024, 04:02 AM
                              MT3608 Step-Up Converter IC Datasheet
                              The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                              Internal soft-start results in small inrush current and extends battery life.
                              The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                              10-07-2024, 05:02 AM
                              How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
                              I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
                              I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
                              what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
                              I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
                              05-11-2025, 05:22 PM
