Cap and resistor question
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Can i use wire wound resistor to replace the one in picture .22ohm
    I think not due to the inductance.
    Also any special requirements for the capacitor 470pf 1kv
    http://nz.rs-online.com/web/p/products/4773544/ for the resistor
    http://nz.rs-online.com/web/p/products/7167309/ for the capacitor
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    Re: Cap and resistor question
    The resistor, it depends on if it is fusible type or not. Do you know if it is connected to the Source pin of the MOSFET or if it is connected to the B+ (positive leg of the main filter cap? More likely the one you pick is OK, its flame proof so it will not catch on fire.
    Cap is OK as long as the higher voltage will still fit into the board.
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      Resistor Is from source to neg. current sense resistor for controller
      My pc
        That resistor is fine to use.
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Regarding wire wound can you confirm that inductance would be a issue.
          My pc
            Inductance will be an issue if used in the path of switching current path such as on the Source pin or on the Drain pin (Drain pin will have transformer or Inductor such as PFC inductor). They do make non-inductive wire wound resistor, I.E. they are used for amplifier load during test.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              As I expected thanks.
              This tv is quite interesting it has what looks like a two phase pfc circuit.
              My pc
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • MidnightRoller
                Can a resistor lose resistance after hot air?
                by MidnightRoller
                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                02-02-2022, 11:46 PM
              • artvandalai
                What resistor ohm will work better to repair this waterpik?
                by artvandalai
                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                01-05-2025, 04:10 PM
              • chth96
                Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                by chth96
                I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                Since then, This AC/DC adaptor have been out of order.
                But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                And Is there any possibility that it will suddenly explode as well as to be out...
                12-03-2023, 04:40 AM
