Help identify component on vsett display board
  • dalle3
    • Jun 2006
    • 8
    • Austria
    Hi, I'm struggling to find what this part is , the board not powering on anymore it is the only part that gets hot when power on button is pressed
    It should be transistor 3kvf
    Cheers
  • R_J
    • 9535
    The logo is for Microne (Nanjing Micro One Electronics Inc.) It is marked as D2 but it may be a voltage detector? Microne does not provide top markings in their datasheets, If the component is defective, you might be able to contact them for information.
    It might be a LDO similar to a ME6231 which has pin1 ground, pin3 Vin and pin2 Vout, so there may be a shorted cap or component on its output causing the ldo to get hot?
    • dalle3
      • Jun 2006
      • 8
      • Austria
      Thanks, have searched but sadly nothing more found 😔
      • truclacicr
        • Apr 2019
        • 299
        • australia
        7533-1 is a 3.3V LDO regulator. Its 5V input goes to pin #2 of D2.
        http://www.e-ele.net/DataSheet/HT75XX-1.pdf
        5V++ is the output of a switchmode DC-DC converter. It goes to pin #3 of D2.
        Pin #1 of D2 is grounded.
        Therefore, D2 could be functioning as a power switch or ideal diode, or maybe a current limited load switch.
        "WE" is a 5V TVS diode, so the output of the DC-DC converter is protected from overvoltages.
        https://www.vishay.com/docs/88390/smaj50a.pdf
        • dalle3
          • Jun 2006
          • 8
          • Austria
          Thank you truclacicr perfectly explained, now i can order part 😃👍
          • adam7
            • Jan 2017
            • 16
            • Kazakhstan
            dalle3,
            It is 3Kxx, 3KPE - ME6216A50XG.
            https://jlcpcb.com/partdetail/497219...6A50XG/C487910
            • truclacicr
              • Apr 2019
              • 299
              • australia
              ME6216A50XG is a 5V LDO regulator. That is, a 5V regulator with a 5V input and a 5V output.
              I don't get it. :-?
              • adam7
                • Jan 2017
                • 16
                • Kazakhstan
                Hi, truclacicr.
                This is a translation of the datasheet from Chinese to English.
                It has an output voltage of Vout=3.3V.
                High-precision output voltage: ±1%
                Output voltage: 1.0V~5.0V
                Maximum operating voltage: 6V
                Very low static bias current (Typ.=6.0μA)
                Strong load capacity: When Vin=4.3V and Vout=3.3V
                I out=300mA
                Very low input-output voltage difference:
                110mV@ IOUT =100mA 240mV@ IOUT =200mA
                Good input stability
                Can be used as a regulator and reference voltage
Name:	3Kxx, 3KPE -  ME6216A50XG.jpg
                • lotas
                  • Jan 2016
                  • 4557
                  • Russia
                  But the case here is not SOT23, but SOT23-3.
                  Check the resistance between pins 1 and 2, if it is low, then most likely the controllers are faulty.
                  • lotas
                    • Jan 2016
                    • 4557
                    • Russia
                    And is there also a connection between points 1 and 2?
                    • truclacicr
                      • Apr 2019
                      • 299
                      • australia
                      adam7, your link points to an ME6216A50XG with a marking of 3KPE. That's a 5V regulator, not 3.3V.
                      I wonder if the designer is using a 5V LDO regulator as a current limited switch.
                      In any case, the output of the regulator is marked as "5V' on the PCB, and the input is "5V++".
                      • lotas
                        • Jan 2016
                        • 4557
                        • Russia
                        It's not clear yet, maybe it's powered that way.
                        • dalle3
                          • Jun 2006
                          • 8
                          • Austria
                          Thanks for helping me out, I was on short trip will be at home and check tomorrow
                          • dalle3
                            • Jun 2006
                            • 8
                            • Austria
                            Have checked resistance is 2.0 ohms
                            • dalle3
                              • Jun 2006
                              • 8
                              • Austria
                              Yes they are connected no resistance
                              • lotas
                                • Jan 2016
                                • 4557
                                • Russia
                                Well, 2 Ohm is bad (short circuit), it could be ceramic capacitors and the controllers themselves, here you can supply 3v from a laboratory power supply to this bus and see what will heat up or cut the track on this line and check where the short circuit will remain, on which side...
