Help identify component on vsett display board
    Hi, I'm struggling to find what this part is , the board not powering on anymore it is the only part that gets hot when power on button is pressed
    It should be transistor 3kvf
    Cheers
    The logo is for Microne (Nanjing Micro One Electronics Inc.) It is marked as D2 but it may be a voltage detector? Microne does not provide top markings in their datasheets, If the component is defective, you might be able to contact them for information.
    It might be a LDO similar to a ME6231 which has pin1 ground, pin3 Vin and pin2 Vout, so there may be a shorted cap or component on its output causing the ldo to get hot?
      Thanks, have searched but sadly nothing more found 😔
        7533-1 is a 3.3V LDO regulator. Its 5V input goes to pin #2 of D2.
        http://www.e-ele.net/DataSheet/HT75XX-1.pdf
        5V++ is the output of a switchmode DC-DC converter. It goes to pin #3 of D2.
        Pin #1 of D2 is grounded.
        Therefore, D2 could be functioning as a power switch or ideal diode, or maybe a current limited load switch.
        "WE" is a 5V TVS diode, so the output of the DC-DC converter is protected from overvoltages.
        https://www.vishay.com/docs/88390/smaj50a.pdf
          Thank you truclacicr perfectly explained, now i can order part 😃👍
            dalle3,
            It is 3Kxx, 3KPE - ME6216A50XG.
            https://jlcpcb.com/partdetail/497219...6A50XG/C487910
              ME6216A50XG is a 5V LDO regulator. That is, a 5V regulator with a 5V input and a 5V output.
              I don't get it. :-?
                Hi, truclacicr.
                This is a translation of the datasheet from Chinese to English.
                It has an output voltage of Vout=3.3V.
                High-precision output voltage: ±1%
                Output voltage: 1.0V~5.0V
                Maximum operating voltage: 6V
                Very low static bias current (Typ.=6.0μA)
                Strong load capacity: When Vin=4.3V and Vout=3.3V
                I out=300mA
                Very low input-output voltage difference:
                110mV@ IOUT =100mA 240mV@ IOUT =200mA
                Good input stability
                Can be used as a regulator and reference voltage
Name:	3Kxx, 3KPE -  ME6216A50XG.jpg
                  But the case here is not SOT23, but SOT23-3.
                  Check the resistance between pins 1 and 2, if it is low, then most likely the controllers are faulty.
                    And is there also a connection between points 1 and 2?
                      adam7, your link points to an ME6216A50XG with a marking of 3KPE. That's a 5V regulator, not 3.3V.
                      I wonder if the designer is using a 5V LDO regulator as a current limited switch.
                      In any case, the output of the regulator is marked as "5V' on the PCB, and the input is "5V++".
                        It's not clear yet, maybe it's powered that way.
                          Thanks for helping me out, I was on short trip will be at home and check tomorrow
                            Have checked resistance is 2.0 ohms
                              Yes they are connected no resistance
                                Well, 2 Ohm is bad (short circuit), it could be ceramic capacitors and the controllers themselves, here you can supply 3v from a laboratory power supply to this bus and see what will heat up or cut the track on this line and check where the short circuit will remain, on which side...
