Dremel 8220 turns on when it feels like it
  • spleenharvester
    • Mar 2010
    • 921
    I've got a Dremel 8220 here that's had maybe an hour's use on it tops from brand new, so the brushes are definitely fine.
    The fault is it just doesn't switch on sometimes. This can be after you've just used it or from cold. If you pull the battery and re-insert it will fire up straight away, every time, so it doesn't seem to be a physical issue with the power switch. Once on it works perfectly until you switch it off again, then it's pure luck whether it fires up again or not without pulling the battery.
    I've not really worked on these kinds of tools before so would appreciate some pointers on what to look for when I pull the PCB. Or should I try a new battery first?
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8342
    I would feel like smacking it against a wall. Get it exchanged under warranty if it only has an our of run time on it,
    • spleenharvester
      • Mar 2010
      • 921
      You are probably right lol, it's still under warranty so I'll just send it in. Cheers
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
        Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
        Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
        ( needs more cam circuits for the machine to work correctly again )
        https://www.ebay.com/itm/275321870186
        To
        3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
        ( not 4 positions but the right amount of cams circuits )
        https://www.ebay.com/itm/274660439950
        I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
        03-18-2023, 05:12 PM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
