How to stabilize AC voltage to CNC machine
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Or moving. Lol
    Nah, 9kva is not cutting it. You need something more closer to 15kva! You need to transform 208V to 240V per phase. Problem with that is while it works when the power is low, you got way too much Volatage when the power returns normal. If you put in 208V and get 240V out, what do you get when you put in 220V per phase? 253V! That is 438V 3 phase and above your 10% upper tolerance rating. So, you be darned if you do and still darned if you don’t.
    Oh yes, that would overshoot the maximum voltage tolarence.
    How about something like this?
    https://www.zx-ele.com/automatic-vol...or-stabilizer/
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Yeah, that's more like it. But it will cost you 2 arms and both legs!
      • unimatrix93
        • Oct 2021
        • 347
        • Magyarország
        I found some on aliexpress for 5-600USD. the problem is that shipping to Europe costs at least that much or more. 😆
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
          Now...
          06-09-2024, 10:57 AM
          ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
          Optimized Multi-Phase PWM Controller
          with 6-Bit DAC for VR10.X Application
          The ISL6556A controls microprocessor core voltage
          regulation by driving up to 4 synchronous-rectified buck
          channels in parallel. Multi-phase buck converter architecture
          uses interleaved timing to multiply channel ripple frequency
          and reduce input and output ripple currents. Lower ripple
          results in fewer components, lower component cost, reduced
          power dissipation, and smaller implementation...
          11-05-2024, 03:10 PM
