Is this a suitable replacement for a NTC Thermistor?
  • LameCooter
    • 35
    • US
    I am replacing SCK-20100 NTC Thermistors but can't seem to find em anywhere. I did find a product mfg by Ametherm that might work?
    Edit: Or this one?
    Thoughts?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Is this a suitable replacement for a NTC Thermistor?
    yes they ARE COMPATIBLE!
    Follow the white rabbit.
    • TadTV
      • Jul 2014
      • 4
      Did you buy them and where? Did they work?
      • R_J
        • 9623
        I have seen this in other sets where the relay contacts are bad and all the current continues to flow through the icl causing it to burn up.
        SCK 20100 10 ohm 5.5 amp
        Digikey has 10 ohm 6 amp rated ones SL12 10006
        http://www.digikey.com/product-searc...=0&pageSize=25
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • ezenia
          Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
          by ezenia
          I am not sure where exactly to put this thread, so hopefully this is the best place.
          I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
          The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
          Speed 2 and 3 don't currently work any more.
          I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin...
          06-20-2023, 05:22 AM
        • Benass
          Looking for Suitable Relay Replacement.
          by Benass
          Hello. I have Industrial Washing Machine PCB.
          Customer Requested Relays Replacement.
          I can't find WJ115F1 relays to buy. Looking for some help to identify possible alternative solutions.
          Or any tips, on how to approach this situation....
          04-21-2023, 01:51 PM
        • fytonv
          7 channel NAD receiver,Need help identifying a suitable cap replacement
          by fytonv
          My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
          Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
          09-08-2022, 09:52 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
