TL 072 op amps
  • barry wilkins
    • Aug 2009
    • 172
    TL 072 op amps
    I have been making a circuit using a couple of these op amps.
    On some of these pin 2 voltage is about 3 millivolts different to pin 3.
    A few of are very poor ,could be faulty ?
    It does not to seem to be too much of a problem the output of the differential amplifier seems to zero.
    .Does any one know why.
    Barry
  • mscottdoran@gmail.com
    • Feb 2025
    • 13
    Can you post a schematic of the circuit you are using it in? Maybe it’s just due to the precision limits of the meter you are using to take the measurement? Depending on the circuit and due to the inherent high gain of those op amps, if the output is zeroing it seems like the op amp isn’t “seeing” any voltage difference between the inverting and non-inverting inputs.
      • 31055
      2 & 3 are inputs,
      your supposed to supply voltage not meter parasitic leakage etc.
      if you look at page 26 of the datasheet you will see they are not identical internally anyway
      • redwire
        • 3910
        It's normal to see 3mV difference; Input Offset Voltage VIO spec is 3-10mV for the TL072.
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • Tarot Superstars
          Short Circuit tester
          by Tarot Superstars
          Hello.
          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
          Link
          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
          https://www.youtube.com/watch?v=0eixDdCpiO4
          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
          09-25-2023, 09:11 AM
        • Alimash
          op amp circuit function?
          by Alimash
          I am repairing a ups which doesn't turn on ,it has the following ICs:
          SG3525 used to drive inverter mosfets.
          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
          A LM358 and TL074 for control mechanism and of course the uController.
          The SG3525 is shutting down every time the ups is turned on.
          I want your help to know the function of LM358 and TL074 in the system.
          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
          07-31-2025, 07:45 AM
        • M1NEBLANK SHOW
          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
          by M1NEBLANK SHOW
          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
          Schematic and Boardview here
          04-04-2025, 03:57 PM
        • прямо
          Viper22A 5VSB circuit
          by прямо
          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
          01-13-2024, 07:05 PM
