please help identify this component
  • picante
    • Jun 2014
    • 5
    • New Zealand
    please help identify this component, it thin it might be some type of PTC fuse
  • dj_ricoh
    • 2073
    Re: please help identify this component
    I think its a radial Inductor
    • selldoor
      Slow Learner
      • 7870
      Looks like an Inductor board marking begins L ?
      basic test is for conductivity
      Google inductors images
      hehehe I need to type quicker
      • dj_ricoh
        • 2073
        :P
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          Value might be 1000nH. Looks like a ferrite drum core
          PeteS in CA
          • picante
            • Jun 2014
            • 5
            • New Zealand
            Thanks, resistance measures 4.88 ohms.
            • picante
              • Jun 2014
              • 5
              • New Zealand
              after searching for radial Inductor in google images it definetlly looks like components on this page.
              http://www.murata-ps.com/en/news/new-products/321
              Thanks again.
              • Francesc V.
                Help me to identify this Thermal fuse from my sister's mixer
                by Francesc V.
                Hi everyone:
                This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
                My understanding is that it should be (NC) normally closed and open at 85C?????
                Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
                Wording in the back......... "limitor 16", "T160".
                Thanks in advance,
                Francesc....
                03-18-2025, 05:48 AM
                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                by momaka
                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                09-19-2021, 08:44 PM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • jesterace
                Samsung UE46ES8000 Blown fuse but no other signs of short
                by jesterace
                Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                09-11-2024, 03:14 PM
              • jshhh
                Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                by jshhh
                Hi guys,
                I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                Anybody know how to remove this type of fuse?
                (The fuse is toward the bottom of the image labeled F2)...
                06-17-2025, 01:35 AM
